Coilover
premroy
Decided to go for the H&R Coilovers mod tomorrow. My rim is 19". I hope that it will not rub the fender. Now is 3 fingers gap so can lower to 30mm...
Any suggestion will be good.
Regards
won't rub........................
cheers
anyone knows where can we service the KW?
can autovox do servicing? do they have the full equipment?
sorry i sua ku never visit them before..
if you buy from them of course sent back to them..........
cheers
hello everyone
welcome to this forum.Here u find all your questions and get your answers.
PRO-STREET-S | Coilovers – Adjustable Ride Height
High Performance, Eibach Tuned Coilovers
Easy Ride-Height/Corner Weight Adjustability Lowering zero.8" - 3.0"
Designed for optimum Street and Track Performance
Rust-Free chrome steel Technology for easy Adjustment—Year when Year
Legendary Eibach Suspension Quality and standardisation
One-Year warrantee
Now you'll get every corner of your vehicle trying and engaging at its easiest. Eibach´s PRO-STREET-S, untarnished steel-bodied coilover spring/damper packages permit serious drivers the flexibility to quickly alter the ride height and corner weight of every individual wheel, giving them the last word in flexibility for precise street and track standardisation.
The Eibach PRO-STREET-S is meant, tuned and tested 100% in-house by our suspension engineers and ride management consultants. Spring rates square measure absolutely matched to the performance damping of the hightech coilover shocks. With the Eibach PRO-STREET-S put in, you'll forthwith expertise a additional precise turn-in response, improved handling, and increased cornering grip—in any performance driving state of affairs on the street—or lower lap times on the track.
MULTI-PRO-R1 | Coilovers with Single Adjustable Rebound and Compression Damping
THE ULTIMATE IN TUNABLE SUSPENSION PERFORMANCE
Monotube style for optimum Street and Track Performance
Spring Rates will be Tuned with a good vary of Eibach Motorsport ERS Springs (available separately)
Precise Spherical higher Bushing Mount
Stainless-Steel/Teflon decorated Reservoir Lines
100% Designed and engineered at Eibach U.S.A
One—Year warrantee
For the last word in tunable suspension performance, Eibach has developed Multi-Pro coilovers, specially tuned spring/damper units that permit you to extract the last ounce of cornering power from your late model performance automobile. The Coilover style enables you to exactly tune the corner weights for optimum handling balance, and therefore the big selection of the damping adjustability enables you to tune for the comfort, final grip, or something in between. These suspension kits square measure excellent for the club racers or drivers United Nations agency demand the high performance handling and optimum ride quality that Eibach is known. :zoro:
  • High Performance, Eibach Tuned Coilovers
  • Easy Ride-Height/Corner Weight Adjustability Lowering 0.8" - 3.0"
  • Designed for Maximum Street and Track Performance
  • Rust-Free Stainless Steel Technology for Ease of Adjustment—Year after Year
  • Legendary Eibach Suspension Quality and Tuning
  • One-Year Warranty
Now you can get each corner of your vehicle looking and performing at its very best. Eibach´s PRO-STREET-S, stainless steel-bodied coilover spring/damper packages allow serious drivers the ability to quickly adjust the ride height and corner weight of each individual wheel, giving them the ultimate in flexibility for precise street and track tuning.
The Eibach PRO-STREET-S is designed, tuned and tested 100% in-house by our suspension engineers and ride control experts. Spring rates are perfectly matched to the performance damping of the hightech coilover shocks. With the Eibach PRO-STREET-S installed, you will immediately experience a more precise turn-in response, improved handling, and enhanced cornering grip—in any performance driving situation on the street—or lower lap times on the track.
  • Monotube Design for Maximum Street and Track Performance
  • Spring Rates can be Tuned with a Wide Range of Eibach Motorsport ERS Springs (available separately)
  • Precise Spherical Upper Bushing Mount
  • Stainless-Steel/Teflon Braided Reservoir Lines
  • 100% Designed and Built at Eibach U.S.A
  • One—Year Warranty
For the ultimate in tunable suspension performance, Eibach has developed Multi-Pro coilovers, specially tuned spring/damper units that allow you to extract the last ounce of cornering power from your late model performance car. The Coilover design lets you precisely tune the corner weights for optimum handling balance, and the wide range of the damping adjustability lets you tune for the comfort, ultimate grip, or anything in between. These suspension kits are perfect for the club racers or drivers who demand the high performance handling and optimal ride quality for which Eibach is famous.
2013 MERCEDES BENZ SL-CLASS
Whats the prices?
