Concealed wiring for GPS
Hi anyone know an electrician to do concealed wiring at Alexandra village coz I live nearby.
Basically I want to hard wire the GPS's usb cable so that I don't have to always use the cig socket which is a little irritating as mine is under the storage panel near the gear stick so the panel is always open.
Thanks
Any audio shop should be able to do it for you. I would recommend AutoSpritze, look for Ah Boon.
Hi !
New to forum, I intend to get Garmin 2575 to serve as GPS n recorder.
one workshop has quoted me $75 to conceal the wire (connect to ATC?) and ensure will not void warranty, however
did a check w C&C they say will void warranty. How do concel wiring w/o voiding warranty?
any advice is appreciated ...Thanks ! btw any workshop to recommend near west coast...
2nd that.
Didn't know you are a fan of Ah Boon :)
Mention my name Mr. Seah to Ah Boon might help you get discount 5 cents or 10 cents from Ah Boon! :lol:
Do a search on the forum, topic has been discussed many times. These threads should be able to give you your answer.
Thanks !
Call up C& C and they recommend autotrend ...quoted $40...
bought the Garmin 2575 at Parasilk $389...Zion raod quoted
$449 ...so much diff??
Guess U have to do some homework before buying :)
Best buy is at IT or Electronic shows & at times freebies too.
that time I mentioned your name and instead of giving me 10% discount, Ah Boon charge me 10% more....
He gave me 5% off your 10% :)
I mentioned ur name and Ah Boon LL gave me $10 discount
When he told me that, I had to buy him roast duck drumstick rice :)
Just imagine you see nothing else of the cable except the USB/microusb plug coming out from your front windscreen to your dashboard.
