Rim fitment issues
implosion
PCD is spot on and rim width seems fine but the ET35 offset should make the wheel stick out slightly from the fender.
Just to give you an indication of what to expect, a staggered setup for the W204, the front is 17x7.5 ET47 (225/45) and rear is 17x8.5 ET58 (245/45).
Sorry, to ride on this thread.
Any bros current using rims with offset of 42 on FL W 204?. I am looking around for 18" rim upgrade but not quite sure if offset of 42 will to be too far out and rubbing the fenders. I undstand the stock 17" rim has a offset of 47 and I did a online calculation show that 18" et42 will extend additional 11mm out. I am still waiting for delivery of my ride so cannot measure it and compare physically.
Gurus here can advise?
Thanks in advance!
  • 3 months later...
I think if front is 225/45....rear should be 245/40.....not 45.
I'm on stock suspension with 18x8 ET35, flush swee swee all round. Full load on (5 adults) and no rubbing issue. But don't go for 18x8.5, will rub rub....can check out my avatar for the rim... :D
Not true bro..
For rear wheel, 8j ET 35 vs 8.5j ET40 vs 9.5j ET47 all flush swee swee no rubba rubba
Will 18x8 PCD 5x112 et44 non staggered able to fit W204?
Should not be a problem!!!
Will it be able to fit W211 too?
Might not clear the brake calipers!
