Topic about Honda
  • Replies 170
  • 1 year later...
Guest fruitcakepablohoney
sneak preview..
Hot hatch Honda legend is set to return – and the new Civic Type R will have a turbo engine
The next Honda Civic Type R will not only be the fastest version yet – it’s tipped to be Honda’s first-ever turbo road car. And our sources in Japan say tuning expert Mugen is already well underway with development.
The Type R has already achieved cult status in the UK – Europe’s biggest hot hatch market – thanks to its combination of a high-revving naturally aspirated engine and aggressive styling. But in order to meet emissions regulations, this latest model will tweak the formula slightly.
Instead of the previous 2.0-litre naturally aspirated engine, it will use a 2.0-litre turbo designed to comply with Euro V emissions regulations. A similar engine will feature in Honda’s 2012 British Touring Car Championship challenger.
Adding a turbo will give more torque lower in the rev range, so a higher gear can be used more often to boost efficiency. Stop-start is also likely to be fitted.
Just as VW hiked power with its latest Golf GTI, so Honda will increase the Type R’s output – but not by much. A figure of 210bhp would allow a 0-62mph time of less than 6.5 seconds and a top speed approaching 150mph.
Based on the new Civic seen at last month’s Frankfurt Motor Show, the Type R gets the standard car’s front grille, slim headlights and LED daytime running lights, although most of the bodywork will be uprated.
A front end with large mesh air intakes, a lower chin spoiler and chunky side skirts will boost the visual impact, while a rear diffuser and extended spoiler aim to increase stability at high speeds. Also helping the car’s balance in corners is the standard Civic’s longer, wider chassis; this should also improve ride comfort and grip.
Don’t expect refinement to match a Mercedes S-Class, however. The Type R has always been an extreme proposition and that’s the way it will stay.
The steering is set to be pin sharp, while the six-speed manual box will use a stubby gearlever for snappy changes. Plus, the suspension will be firm, to cope with track work as well as blasting down B-roads.
In a break from tradition that matches the turbocharged Ford Focus ST – a key competitor for the Type R – Honda will offer the car as a five-door only. Prices are expected to start from around £23,000 when it arrives in 2013.
Read more: http://www.autoexpress.co.uk/news/autoexpressnews/273562/honda_civic_type_r_is_back.html#ixzz1ZvA6kgUa
hi guys, i have been experiencing some problems with my 4 year old honda fit. recently the car started to vibrate violently when moving off from stop. just like driving a manual car.
what could be the problem? the vibration only occurs when moving off.
Bro, could be tranny issues. Cause Honda fit's gear box is not exactly good. Check with your regular mechanic for more details....
Guest hkhamateur
Bro, a warm :peace: :welcome:
Bro Wes make a point. :becky:
It cld aso b one spark plug faulty or MAF sensor defect or cylinder pressure dropped! :whistle:
Best approach, bring it to Kah Motor fr a check up! :hand:
hi yamapi
should be the engine mounting that needs to be replaced. i had the same problem with my jazz 2 years ago. everytime when i move off after stopping there would be bad vibration.
its always the start when i step on the accelerator. changed my engine mountings and the problem is gone
Guest hkhamateur
twisti wrote:
hi yamapi
Oh...ya...we missed out e engine mountg! :becky:
Its important too! :whistle:
Kam Sia bro twisti, almost left this out! :hand:
Ya engine mount too bro! But does your car rattles and produces a very Loud vibration sound when drive off? If yes it is engine mount. Look for Huat lee at autobay. He shld be able to solve your jazz problem! :)
  • 8 months later...
