April Driveaway Trip to Penang (OLD)
  • Replies 446
Guest jenvid
David, can you help me check do PsP car charger can charge our WT ??? Kum Xia
The base of the WT takes an input source of 12v, so any ciggy adapter with the std ctr +ve jack would do the trick.
I believe PSP charger pushes out 5v or 7.?v
You dont need a special charger unless u intend to charge the lithium batt direct.
I will lug ard a few of these adapters to share ard for the trip. anyone who has a std ciggy adapter, pls bring along at the meetup. I will try to solder the correct adapter for u folks.
Guest jenvid
SGMerc Part II Driveaway Penang.
Name List:
1. Kompressor x 1 (WT)(1 Room Twin Bed share with Victor Confirmed)
2. Sy69u - x 1 (WT) (1 Room Queen Bed Confirmed)
3. Victor - x 1
4. keltanky - x 1 (WT) (1 Room Twin Bed share with Jeff Confirmed)
5. Jeff Keng x 1 (WT)
6. Cklasse - x 2 (1 Room Queen Bed Confirmed)
7. SillyWilly - x 2 (WT) (1 Room Twin Bed Confirmed)
8. Jenvid x 1 (WT)(1 Room Queen Bed Confirmed)
9. Protoss x 2 1/2 (WT) (1 Room Queen Bed)
10. Dash x 2 (1 Room Queen Bed Confirmed)
11. C35 x 1 (WT) (1 Room Twin Bed Confirmed)
12. C55 x 1 (WT) (1 Room Twin Bed Confirmed)
13. Winson x 1 (C35 must get Winson a WT)
14. 9339 x 2 (WT) (1 Room Queen Bed)
10 Rooms - 5 Twin, 4 Queen, 1 Queen Not Confirmed (Protoss)
Closing date 14th March 2008 (2359). Anyone interested, please PM me for availablility.
Convoy Group A & B.
All participant MUST get a walkie talkie, PM me for detail.
Thank You
Touch n Go card
1) Protoss
2) Jenvid (RM$250)
3)
4)
5)
6)
7)
9)
10)
Those joining the Penang trip.
Anyone want to buy Touch n Go card?
err can someone fill me in. The last time I read abt touch & go, u need to pay some deposit for card ala our MRT card (eh call wat ah) then each time u top up also got handling fee<- At SG Maybank teller...
Tio bo ? seems a bit of charges for some minor inconvenience...
Is just a deposit of 20RM and personal particular in case of card fault or refund,if dont mind the refund,anyone can help buy on behalf, add money can do at ATM Maybank Malaysia but you need to have a account there.
Guest jenvid
errmm moved my post here from the meetup as it has digressed.
The only thing here is whether we need a regulated 12V supply to the base unit. Anyway I have a whole bunch of accessories. Mini lead acid, 7.2v (3.3AH) batts(direct to WT). I will try to sort out all the stuff & lug them down to the meetup.
Ok I have managed to strip apart the WT & tested a few batt combi. I think this the best option if you dont play RC cars. Buy 1 male & 1 female ciggy adapters, cut the AC power adapter wire to 2, female socket goes to ac adapter & male ciggy adapter connect to the wire socket going to WT base unit.
This way we can lug along only 1 eqpt for long haul trip & still charge WT while in car or at the hotel.
Bear in mind that it will take abt 4 hrs for a full charge.
Personally I feel that a spare batt is necessary if one drive alone & yak a lot as the base unit is light & th WT is heavy & it is pretty difficult to slot the WT back to base unit while driving.
So far I have 4 spare cig adapters and since we are on a long trip, we shld be pass the adapter around in between breaks on the way up or down.
Without a doubt the following needs a charger or spare batt
Convoy leaders
Sweepers
Entertainers/Comedians :)
Navigators
(I will try to lay my hand on a second Nuvi[currently on a world tour]) I do have another 2 garmin gps, 2 Holux gps for anyone who wish to hook up using either WM6 PDAs/Palm or Nokia N/E series phones.
You need to download the Garmin MobileXT or Garmin Que to use the malsing maps.
Those with mapking software can also download the mapking SGMY map from Malsingmaps.com
Once u use your phone/pda as navigator it will need a constant power supply.
I will lug my lappy down to help anyone who wish to install.
Guest sy69u
Convoy leaders
Sweepers
Navigators
thanks bro. i will bring my palm pda. need u to help me to install mapking.
i also have 2 ciggy chargers tat can fit into the charger. will also bring tat.
Guys and Gals, even as the closing date for this drive stated are 14th March which are already passed, We are still welcome whoever interested to join us at any time, Pls PM our "DiaLo" Kompressor for detail. The more the Merrier ;), it will be a Fun and Memorable Drive with lots of activities and entertainment by our Bro SY. See ya... :)
Guest fruitcakepablohoney
Navigators
Jenvid, I just got a Nokia N95 8GB, need your help. thanks 8)
Navigators
If on Handphone, it will charge the airtime if i am not wrong ???, pls comfirm before big bill comes. :o
Guest sy69u
alamak, i kena arrow again. i innocent lah i tell u, innocenttttttt.
Navigators
David, i have this HTC tytn which i belive it got inbuild receiver for gps, what should i do next.
Guest jenvid
ok guys with all the HP with built in GPS...
I got bad news. The GPS is crap.... Dun believe me, take your HP, load the GPS program stay in an open area with no bldg & see how long your gps get a fix.
Chances are you need an external bluetooth GPS. I have managed to round up 5 of these for the trip. 2 garmin & 3 holux
GPS program. For those using non garmin based GPS, you will need to get hold of a copy of Mapking. Think it cost ard $60, you will need a bluetooth GPS probably cost u between $199 to $250. If you are lucky to get garmin Que to work, then u only need to lay your hands on a GPS.
The nokia maps will require a data connection to constantly d/l the map. Dont even try in Msia. 1MB is SGD20
Those with HTC/DELL/HP/DOPOD/Palm with Windows Mobile 6, you can load in either MobileXT(require Garmin GPS) or GarminQue (generic GPS)
I have not twiddle with those PDA with builtin GPS before, but I guess we can test it out at the meetup.
Sy69U: Your palm got connect cables ? or you got a lappy to lug along to do an install ?
Guest jenvid
Name List:
3. Victor - x 1
8. Jenvid x 2 (WT)(1 Room Queen Bed Confirmed) [Need to change to Twin pls]
9. Protoss x 2 1/2 (WT) (1 Room Queen Bed Confirmed)
14. 9339 x 2 (WT) (1 Room Queen Bed Confirmed)
11 Rooms - 5 Twin, 6 Queen
Convoy Group A & B.
Thank You
Touch n Go card
1) Protoss
2) Jenvid
3)
4)
5)
6)
7)
9)
10)
Depart - 11th morning (4.00am), Arrive Penang 11th morning (3.00pm)
Return - 14th noon (1.00pm), Arrive SG 14th night (9.00pm)
3 nights stay in Penang.
Itinerary include:
Shopping - Night Pasar Malam, Gurney Plaza, Queensbay Mall
Sightseeing - Kek Lok Si Temple, Wat Chayamangkalaram Temple, Penang Hill, B-Road Drive Round Penang Island.
Food - Char keow Teoh, Asam Laksa, Hokkien Mee, Curry Mee, Lok Bah, Nasi Kandah & Chendol, Chee Cheong Fun etc
Name List:
3. Victor - x 1
8. Jenvid x 2 (WT)(1 Room Twin Bed Confirmed)
Convoy Group A & B.
Thank You
Touch n Go card
1) Protoss
2) Jenvid
3)
4)
5)
6)
7)
9)
10)
Guest jenvid
Gentlemen, Good News
Today Yen, Jeff & myself (Moderators of SGMerc) met Kelvin from MBM WheelPower. MBM Wheelpower is offering to check our vehicles at NO LABOUR COST before our Penang trip.
6. Jenvid - 325i (E93)
*sob* *sob* my e93 :'( off to wkshp...a very ex Melaka trip...
Guest Protoss
Bro,
Wat happen?
Guest jenvid
and the b road was a very light one, i dun even call it b road at all.
David, share with us what happen. yours under warranty right? so it is PML ex not you ex la.
*sob* missy took the e93 and kiss a pillar in the carpark dead slow big time... sigh....
Guest Protoss
Bro,
I can feel your pain. :'( Our cars is like our baby. ;)
Hope PML can nurse your E93 back to shape at a reasonable price. :-\
Guest Protoss
Itinerary include:
Name List:
3. Victor - x 1
6. Cklasse - x 2 (WT) (1 Room Queen Bed Confirmed)
Convoy Group A & B.
Thank You
Touch n Go card
1) Protoss
2) Jenvid
3)
4)
5)
6)
7)
8 )
9)
10)
