Wao lao, problem with my coupe after only 4 month!
Just realised that the driver seat does not move forward for easy access when pushed forward. It was still working yesterday but only the passenger side is working now!
Anyone has a similar problem? Any idea what's the downtime like?
树大必有枯枝,人多必有白痴。
树无皮必死无疑,人不要脸天下无敌!
Same thing here. I realise that is bcoz the seat didnt lean forward enough. So the easy excess function not activated.
BM, you mean the back seat is not leaning forward enough? I'll try later to see if that's the case
Yes LF, its happens to me couple of times. Initally i thought i didnt activate the easy excess function!! So did my own troubleshooting found that the "lean forward not enough issue"!!
Mine confirmed kaput. Tried leaning it forward to the max still cannot!
Yr seat confirms nothing blocking the seat leaning forward? Like weapons etc
Wah lao, don't have lah. seats are moving fine when i use the controls...
树大必有枯枝,人多必有白痴。
树无皮必死无疑,人不要脸天下无敌!
Ok, stoopid question. What about the passenger? Same issue? If only driver's seat, try this
1) lean the seat forward then push the whole seat forward manually its shld move forward.
2) get to the rear seat, give a good punch or leg to kick it hard.
If apply the above method & its doesnt work then bor bian lor.
Boss, you are not joking about point 2 right?
The passenger side is working perfectly btw.
树大必有枯枝,人多必有白痴。
树无皮必死无疑,人不要脸天下无敌!
Nope!! Be gentle abit lah. Try it out, i suspect sooner or later is my turn.
problem resolved! was at C&C, reset the error code and everything works fine too!
Is there any warning error code?
Nope, it only showed when they plugged in the OBD diagnostic tool!
树大必有枯枝,人多必有白痴。
树无皮必死无疑,人不要脸天下无敌!
  • 4 months later...
