w124 master piece - need advice.....
Guest clarkewan
Guest clarkewan
keltanky ]
i' wrote:
http://cgi.ebay.com/ebaymotors/PLUG-IN-keyless-entry-for-MERCEDES-w124-w126-w201-r107_W0QQcmdZViewItemQQcategoryZ33723QQihZ013QQitemZ230231677496QQrdZ1QQsspagenameZWDVW[/url]
currently my key is going to give way soon!!
last week, it auto lock me into car! when i switch off engine!! :death:
if u r game to order, i am game....
let me know can?
we do it together??
my contact is 96777707
hahahaa.....
my name is clarke....
cheers!!!
  • Replies 299
Guest clarkewan
headlamp u can try Tye Soon or Chua Auto.... Tye Soon shld be cheaper with Hella products. If u thinking of doing HID conversion keep ur old headlamp rear cover cos u will need to cut thru the rear cover to run the HID wires to the ballast. EFX Euro EFFECTS HID kit is a gd choice...
oh...
did a little research...
bought from surpass at kaki bukit for S$180 a side....
waiting for my hid kit to come in now
going to install into my mercs probably next week....
need to put in a canceller though if not got check lights....
:D :D :D
using the hi lo beam type and going for 4300k original hid colours....
:D :D D:
cheers.....
Guest clarkewan
The audi key looks good! Tempted to do too!
Anyone wanna do together? Maybe can get better price..hehe.. :afro:
can do vw or audi style key for w124 masterpiece original meh?
:D :D :D
i dun mind if can.....
sian of my old and spoil key thingy....
Guest clarkewan
make my key there too..... :punk1: :punk1:
SO SAD....
just came back from there...
he is unable to make it...
still not solved.....
bro, are you the same clarkewan from ssc?????
yes...
i am the same clarkewan from subaru club...
:D :D :D
i just bought a w124 masterpiece...
:D :D :D
Guest clarkewan
just did a few days ago...
window tinting...
:D :D :D
also realised my third brake lights also gone case...
sian..
bought again from surpass at S$58.00
going to change the bulb to LED too...
:D :D :D
using LED i guess would be better cos not so hot and the bloody plastic will not melt....
:D :D :D
will take more photos of my mercs when i done up more things...
hahaha....
also changed many lights to LED liao....
:D :D :D
Guest clarkewan
hope to see u at this month's meet up...
u mean me?
hahaha...
let me do up my car nice nice first
then i go and meet u guys up...
:D :D :D
i feel like changing my side fenders too....
one side not so nice liao...
but i heard is quite expensive??
unless get after market taiwan made......
side fenders not nice? front left and right? can get from scrap yard mah no need get brand new... its okay if ur car still not done up yet. just come down and meet more 124 owners and all the other forumers... its at 28th of this month
Guest clarkewan
side fenders can find from which scrap yard?
:D :D :D
cheers!!
28th is sunday??
btw.... where is it going to be at?
i dunno if i can make it....
cos family day...
if not i will be at bbdc learning bike...
:D :D :D
haaa....
i also gian kawaski ksr bike
so decided to take class 2 b so can go riding too...
:D :D :D
ah....
i prefer to leave the bulbs in there...
my fogs i am going for 3000k...
drive up to malaysia would be great...
:D :D :D
haaa....
:D :D :D
oh?
i also dunno if my third brake lights are original anot?!?!?!
at 58 dollars, u think is original?
holy cow....
they dun have grey so i ended up buying black....
since my rear windscreen is tinted black i guess i just leave it black...
:D :D :D
rims?
i think i keep it stock...
stock looks for rims nice mah...
Guest clarkewan
huh?
u meant my originals are only 15"?
i must go check...
:D :D :D
didnt notice...
hahaaa.....
pcd so odd 120....
:D :D :D
buy the 3rd brake lights liao...
no choice lah...
since is not original then nevermind...
as for the meetup
i try to go....
Guest clarkewan
i also heard that the engine is running on the hot side for w124?
any good if i were to put in an oil cooler??
had fitted up with grounding and voltage stabliser.....
i find that my car go problem with cold start....
the engine like cannot start properly when cold....
is it anything to do with the cold start valve??
:D :D :D
thanks for sharing......
cheers!!!
Guest clarkewan
- wat problem with cold start? vibration or idling too low?
- wats ur normal operating temp shown on ur meter cluster? if its at 90 Deg C when warm up its fine
vibration first then engine cease
then have to restart and press on the accelerator slightly...
blow a bit and ok liao...
only when cold start....
other than that is ok....
oh.... and driving, got a rough sound too
think have to send to a workshop to get it check first...
btw... is it on timing chain or timing belt?
as for the temperature i didn't know what is the exact temp. but is below the half marking....
i hope to run a slightly cooler engine....
hopefully a oil cooler can help....
wat u think/advice?
Guest clarkewan
original is 15" this car come with 195/65/R15 hope to see u ard its gd to have more 124 owners coming
ah...
ok...
i go check later...
hahaha.....
:D :D :D
thanks....
if i up the rims...
my fuel will up too...
car heavy right?
this M111 engine is on timing chain. rough sound maybe the engine damper is gone or tensioner. it might be timing chain guide oso. but most likely could be the engine damper cos the rubber busing is weak... need to mod the bushing and it will last u the life time of the car... as for vibration on cold start is it during the morning or at each start up? for the temp u mention is it in between the 80 Deg C mark and the next marking?
Guest clarkewan
hmmm....
for the cold start thingy....
i think it happens a few times....
like i reached my destination....
after i parked for about 15mins...
i came back...
i started the car....
it vibrates and then it cease
i have to start again...
i guess this is not consider cold start right??
so far it happens 6 times from the many starts.....
as for the sound....
where would u recommend me to go for a check?
and can also send for servicing?
i dun mind changing some items to make the sound gone...
:D :D :D
if it is timing chain then good....
no need to worry about changing timing belts....
for the temp...
yes...
about there.....
80 over degrees....
after full warm up....
wow...
if i can clock 300km on half a tank i would be happy...
let's see....
:D :D :D
-omg... i m afraid that the vibration is due to a head gasket problem... need to do a pressure leak down test to confirm if the head gasket is leaking...
-timing chain has got life span oso haha
dun be too happy haha
-its normal if ur reading is between 80 Deg C and the next marking.
SO SAD....
yes...
:D :D :D
:D :D :D
ho...ho....ho.... the HID "si fu" is in the house :punk1:
must drop by your place next week to take sneek peep at your "pimp my ride" progress!!!!!
can customise the scuff plate? mine missing one piece :tongue1:
