My Humble W211
SteveC
@Paladin: Thanks! but i might be changing the grille again. Yes. that is up next.
@WML88: Thank you!
@mercc: Pmed you the details on the headlights
Rims changed but not in black. will post up pics soon.
Nice suggestions. those are what i am going to do next.
@jayson Thank you! I will do my best to join you guys for the upcoming meet. Cheers.
@cahn77 yup. Love it too. but with these rims, I am tempted to do something about the brakes...
@blackmercs Thank you! I will like to check if you will have some accessories that I can use to further enhance the outlook of the car. :D
  • 5 months later...
i got the DRL headlight installed with my W211 too....but they are not LTA friendly wor...might have to remove before inspection...also the set i got was from US, i found the light shooting higher on the left hand side which more suitable for left hand drive car...not sure you have this problem?
you might want to install Carlsson DRL to further enhance the look....also not LTA friendly, but i asked the installer to provide me a toggle switch inside cabin, i can turn off when go for inspection.
Yes i have the same problem, left hand side is higher. I guess i was lucky, i managed to pass the inspection with HID lights =)
Regarding the Carlsson DRL, Can let me know you got it from?
Bro,
i got the first set from forumer here then when someone decided to slow down his car by using my car as stopper, it damaged, the 2nd set bought from ebay which actually much cheaper...
remember to put a toggle switch...
