Need help 2006 (PI) E200
AC73
Unable to help u on this one. Try google which i did there are tons of infro to read up.
HI,
Need your guys for help urgently. 1st time buying an used Merc. Saw this PI E200 (W211) http://www.sgcarmart...=254097&DL=1337 May I know is this a FL or Pre FL model? PI & C& C E200 any different ? (beside the OMV) Also what is the meaning for "SBC"? Is this model having the "SBC" problem?
Thank you!!!
Sensotronic Brake Control (SBC)- http://gnnmotors.com/mercedes-benz-sbc-brake-system.html
I think this one should be pre-fl, can check with the dealer?
For pre-fl, try to get one from c&c. Can check this with higher omv-
http://www.sgcarmart.com/used_cars/info.php?ID=254905&DL=1294
IMHO
The said W211 imho is a Pre FL E200ML.
They probably had changed the bumpers, front & rear lamps to FL W211 E200K
but think they forget to change the steering wheel. :)
Therefore it should not be advertised as E200K but E200ML
Here's another ride registered 14th June 2006 as Pre FL E200ML 2 days later than the said ride of 12th June 2006
IIRC The 1st FL came to SG around July or Aug 2006.
FL W211 E200K Steering Wheel
Pre FL W211 E200ML Steering wheel
Your said car steering wheel looks like the last pic on top! :)
Oh yes!
The wood trim are different too!
Hi guys,
Thanks for all the advise, finally bought my 1st merc.http://www.sgcarmart.com/used_cars/info.php?ID=254905&DL=1294
Congras!! Come to april gtg & get mods ideas from the seniors.
Glad to be invited, pls keep me update & I will try to be there. Thanks.
Check out the event folder for all outings.
Hi guys,
Bro AC73,
Congrats on your new ride. I have the same E200ML, Year 2006.
I am thinking to change the suspension system + lowering, looking around for workshops. If you are thinking the same, please let me know, so that we can take a "group buy" approach.
