Cars done up by Dynotechnica
8th July 2022. Mercedes GLA180 doing Xentry diagnostics, Varta battery replacement, boost solenoid and exhaust particulate burn off function.
8th July 2022. Mercedes CLA200 doing suspension noise check and repairs.
15th July 2022. Mercedes E200 doing rear absorber top mounts replacements, transmission pan filter and oil replacement along with full diagnostics.
15th July 2022. Mercedes E250 doing power steering pump replacement, turbo rebuild and belting system noise issues.
4th August 2022. Mercedes C180 coupe doing dimsport firmware upgrade, engine oil solenoid valve and harness replacement.
4th August 2022. Mercedes A200 doing high pressure fuel pump replacement and airbag error.
4th August 2022. Mercedes E250 doing major servicing, rocker cover, belt pulleys, radiator fan, alternator, rear brake rotors, brake pads, and B+ major servicing.
27th August 2022. Mercedes A200 doing auxiliary battery change and Xentry settings.
27th August 2022. Mercedes B180 doing Dimsport new firmware update and Diagnostics checks.
27th August 2022. Mercedes A200 doing Airbag module checks and calibration.
