Cars done up by Dynotechnica
27th January 2022. Mercedes GLA180 doing servicing with engine flush and Ceratec. Engine flush is best to do once every alternate servicing to avoid deposit build up. CERA TEC is a high-tech ceramic wear protection product for all motor oils. CERA TEC reduces friction and wear due to ceramic compounds that withstand extremely high chemical and thermal loads. Prevents direct metal-to-metal contact, thus increasing the engine service life. The low-friction effect reduces fuel consumption in gasoline and diesel engines. CERA TEC provides wear protection for engines, transmissions, pumps and compressors. CERA TEC should be added to the oil and is self-mixing. Sufficient for 5 liters of motor oil. Provides protection up to 50,000 km. In short Ceratec is a ceramic engine coating that will reduce wear and friction.
