W204 FL Aircon problems
jehkoh
Hi bro snsd555,
here goes.
His name is Ah Weng, mobile 9435 7824.
His workshop is located at Block 3021A Ubi Road, i forgot the unit number, corner unit. Maybe can ask him for those interested.
Hope this can help anyone who need a aircon fix or opinion.
regards
lz
  • 1 year later...
On 7/29/2020 at 8:21 PM, level z said:
i was told by a aircon expert that the newer aircon system does not use clutch system to engage the aircon when you turn on the aircon switch. Newer aircon systems goes by pressure,ie, once you on the aircon, there is a pressure pump inside the aircon compressor that activate the gas to flow. If the pressure pump is no longer as efficient, it will take a longer time to build up pressure in the system and this will delay the aircon 's function.
I was driving a c class and was told the pressure pump can be replaced at about $250.00
hope this helps.
Hi Level Z
i have this same problem have to on and off to get the air con to kick in cold air.
Did you manage to change the pressure pump to solve this issue?
I believe compressor is still ok because after kicked in air con is cold for the whole day.
Ok got the price and WS info from the thread.
Thanks for your advise!
1 hour ago, Cookie said:
Hi Level Z
hi cookie
try to see if possible to get your air con guy to check on the pressure pump, it is creating enough pressure at start up to kick the gas to flow.
As posted, my problem was it took a while for the cold air to come in as my compressor pressure pump a bit longer than usual to get the gas flowing, the mech suspect it is due to the pressure pump issue.
PS : The pressure pump is part of the air con compressor.
  • 3 years later...
My car C180 1.6 got the same problem
Whenever park less than 12 hr. Air con work perfect
However after 12 hr. It take around 5 min with hot air blow out then after that run perfectly.
I change new compressor and new climate control unit. But the problem still exist. I will check with another shop. I suspect some valve problem. Will let you guy know.
