Brake Pad/Rotor/Disc/Sensor - which supplier is the BEST in Quality and Price
Spincer
Dear all,
Need advice whether the below quoted price is reasonable as i found a weird on the price to replace the brake disc, pads and sensor as price gap is too much. How come dif. supplier quoted the brake pad is 1 or 2 pcs ?
Supplier A
Front brake disc (x 2) @ $40 x 2 = S$80
         brake pads (x 1)     $50 = S$50
         wear sensor (x 1)   $5 = S$5
Rear brake disc (x 2) @ $35 x 2 = S$70
         brake pads (x 1)    $40 = S$40
         wear sensor (not required)
Total price for the above :- S$245
Supplier B
Frt pad – S$120 x 2 = S$240
Frt rotor – s$115 per pcs x 2 = S$230
Sensor – S$16 per pcs x 2 = S$32
Rr pad – S$95 x 2 = S$190
Rr rotor – $85 per pcs x 2 = S$170
Total price for the above :- S$862
Supplier C
 Brake pad frt $110
 Brake disc  frt $110  x2
 Brake sensor frt $8
 Brake pad rear $85
 Brake disc rear  $85 x2
Total price for the above :- S$593
Please advise which supplier is more appropriate for me to replace the wear off brake pad/rotor/disc.
Thanks
  • Replies 16
Supplier A's brake pads so cheap? $40?
Supplier B's brake pads so expensive? 1 piece $100+ ? Made of what?
Supplier C's pricing is more logical..
by the way, C-Class only got 1 brake sensor..
Bro mind sharing info? I also going to change pads and rotor and sensor...
Can PM me?
Btw W212 got 2 sensors right? instead of one?
This is my quote:
Brake Pad Front & Rear = $140 x 2
Brake Disc Front = $245 x 2
Brake Sensor = $15 x 2
Labour for the above job = $135
All price subject for 7% Gst.
Can PM me?
This is my quote:
Dear Bro,
My is W204 , different model dif. price.
Anyway, Tks all for the advice.
Dear all,
For info and reference, replaced the below at Chip soon (Tampines)
Brake pad, Front - Ceramic : - S$145 (1 set)
Brake pad sensor, Front :- S$8 (1 pc)
Brake Disc, Front :- S$270 (2 pcs)
Brake Pad, Rear - Ceramic :- S$125 (1 set)
Brake Disc - Rear :- S$210 (2 pc)
Labour for the above :- S$160
Total for the above :- S$918
Thanks.
I got my B.pad parts and rotor from goldenlink and prices are reasonable.
Sensor is a must and would recommend ceramic b.pad.
I have changed to ceramic brake pad, it is giving 'squeeking' sound and workshop told me is due to ceramic brake pad, have yours giving this problem?
my w024 on ATE ceramic brake pad sometimes once in a while do squeak during slow braking.. but not very often though.. think some owners on ATE ceramic pads do hear this, but some don't .. need more inputs
