C63 AMG Coupe Wide Body Aerodynamics Full Upgrade
bakuteh
regarding light weight crankpulleys.. some additional readings for you guys to explore..
http://mbworld.org/forums/c-class-w204/286378-automotivedezignz-brand-new-light-weight-power-pulley-w204-v6-v8-2.html
highlighted quote:
1) if just the weight is lightened, expect no improvement, as crank and fw/TC inertia will dominate.
2a) if underdriven, then max power will be in 1st gear, where highest acceleration of pulley and driven parts occurs, now with less acceleration.
2b) if underdriven, a slight improvement in steady state power at higher revs will be due to less power absorbed by driven devices, assuming each device has a constant resistive torque.
From what I understand that aftermarket light weight crank pulley can cause related connecting engine components to give way over long term as it is not designed to work compatibly with other engine parts. Unless you upgrade rest the parts as well. Technical explanation I have no idea, just read it somewhere previously.
Final pics of your ride with your new rims?
Btw whats the damage for the pulley?
Installing of C63 AMG rims will happen this Friday morning and will post the pics ater that.......
Damage is ~ $800 with installation...
Summary of my C63 Mod:
Aerodynamics Body Kit
(C63 AMG Body kits : Engine Hood, C63 Sport Grille, Front Bumper W/DRL, Front Wide Fenders, Side skirts, Rear Bumper W/Diffuser)
- Suspension System
(BILSTEIN B16 PSS10 Coilover Suspension Kit & H&R Spacer Kit)
- Interior
(C63 AMG Steering Wheel w/AMG Logo w/Paddle Shift Programmed, C63 AMG Door Sills Panels w/Illuminated AMG emblem, AMG Door Pins, AMG Seat Emblem, AMG Floor Mats, AMG Sports Pedals & LED lights for Car Boot)
- Exterior
(Mercedes Benz illuminated STAR, AMG Trunk Spoiler Lip, 6.3 AMG Fender Badge & Black Rear Side Mirrors)
- Exhaust System
(PIECHA Quad Exhaust System - LTA Approved)
- Brake System
(AMG Performance Brake System Complete Set (Frt 6 pot, Rear 4 pot single disc)  & Movit Performance Stainless Steel Brake Lines)
- Rims
(C63 AMG Multi-spoke black 19" rims - Front 19"x8" ET 45, Rear 19"x9" ET 54)
- Tyres
Contisport 3 - Front R19 x 235 x 35, Rear R19 x 255 x 30)
- Engine Performance
(MKB High Performance ECU Module, BMC Air Filter, Exclusive MotorSports Light Weight Crank pulley & Power Pedals)
 EXCLUSIVE MOTORSPORTS Light Weight Crankpulley
60% Reduction in Masss
·  Not Underdriven ( for Reliability )
·  CNC Machined Aluminum
·  Improved Harmonic Damper
·  Improved Engine Efficiency
·  Quicker Acceleration
·  Better Gas Mileage
·  Free up 5 HP & 8 NM Torque at ALL rpms
·  Full compatible w/ other mods
·  No ECU tune required
·  Simple bolt-on modification
·  Limited Lifetime Warranty
·  Made In Germany
Thanks for sharing. Cant wait to see yr ride in person. Hope to see you for the coming gtg at kallang.
Minus off the rims, body kits, steering wheels, etc that were sold.....nett spend around $25K which includes Power modifications (ECU mapping, power pedals, light weight crank pulleys), Bilstein Coilovers, Piecha Exhaust System)
Nice mod. $25k spent is awesome.
· Made In Germany
Where can i buy,bro?
Can you feel the different using this? Have you dyno your car?
Thx alot for the help
