Need advice on rims in C250 coupe
  • Replies 25
Here u go
Front 225 x 35 x 19
width 8.5"
offset 45mm
Rear 255 x 30 x 19
width 9.5"
offset 47 or 48mm
Tks
One of the shop recommends using 19 inches width 8" all round but add in a spacer at the rear rims.
The rim is not meant for your model. Skip it unless you die die must get the design
For staggered setup follow blackmerc's recommendations
For squared , all four follow front specs.
Here u go
Front 225 x 35 x 19
width 8.5"
offset 45mm
Rear 255 x 30 x 19
width 9.5"
offset 47 or 48mm
 Hi
With this width will the tyre look under size? Not too sure if front 235, rear 265 will have any rubbing issue?
Hi
Come to the any meetup and see it for yrself.
Why 235 / 265 ?? Without lowering spring likely wont rub, i might be wrong. Gd luck.
Probably will be upgraging my rims by this week.I know that 225/255 is the correct tyre size, but worry that it might look abit under size.:-)
If get 19' will try to follow the correct size.... unless it really look bad on it.
Under size?? I dont think so.
Has changed to 19' rims, tyres a little bit of undersize due to the width of the rims 8.5'/9.5'.
Overall I'm satisfy with the new shoes :-). Too bad Daffy reply came abit late...... (just kidding)
No worries... Cheers
Mine is 235/35/19" front. 265/30/19" rear.
Both mine and blackmerc fitment looks perfect.
I think if yours is run flat tyre, u will probably see the indicator of RFT-(run flat tyre), SSR-(self supporting run flat) or ZP-(zero pressure) on the tyre..........Hope I'm not wrong. If not can call your SE to double check.
Bro
So 235 when steering fully turn on either side, any rubbing issue? Cos the staff told me that will have this problem.
Yc3333 is correct. I never lower my ride, no rubBing issue. Where did u change ur rims?
How about the rims can i use back the oem rims to get 245/40?
Not recommended. It isnt true staggered setup and probably your tyres will look oversized. Standard 17" staggered specs from MB as follows, but you can run something more aggressive than that.
17X7.5j ET47 225/45
17X8.5j ET58 245/40
