Illuminated Star
nala
Chiam!! My iphone cannot view attached pictures. What is that??
GROUP BUY GROUP BUY GROUP BUY.....lol
Read from the other webby that this cost around 170 EUR order from Germany. Someone installed it in his ML 280 CDI and said that the installation really sucks...because if you follow the Instructions you should take of the door and then run harness through, must also remove the airfilter and the rear backseat... But after that installation its only run 5 minutes when driving.. End up he changed his mind then and connect it direct with a switch so that he can have it on anytime he want ...
Read from the other webby that this cost around 170 EUR order from Germany. Someone installed it in his ML 280 CDI and said that the installation really sucks...because if you follow the Instructions you should take of the door and then run harness through, must also remove the airfilter and the rear backseat... But after that installation its only run 5 minutes when driving.. End up he changed his mind then and connect it direct with a switch so that he can have it on anytime he want ...[/size]
Then the person should connect to the ils or the auto headlamp power...
