Urgent Help needed!! - reverse sensor not working?
aflop
  • Replies 16
Wow one thing after another!! How old is yr ride? Recently did you mods yr ride? Like bodykit & ICE thingy?
yea.. how come so many problem.. did you send for inspection when you bought it?
Took over from a friend, but the problems came about when I sent the car for a respray (changed Colour) at a certain workshop at sin ming. Apparently they blew my onboard computer panel while doing it (god knows how they did it).
After that was replaced it all went haywire
Ok you didnt go back to the paint workshop about the haywire?
No one got solution?
I was fiddling lock and unlock buttons on my ride then i heard a beep, anyone know what that beep is for?
Car is 09 pre FL, been driving it for 1 year, only recently got these issues. jialat..
Your ride reverse sensor is installed by
TOMO-CSE AUTOTRIM PTE LTD (CnC outsourced to them)
Click the link for the address:
http://www.tomocse.com.sg/Contact_Us.html
The buggers dont even know how to fix it properly, i gave up after they fixed it. Never going back there again.
Supposedly specialise in Audi and BMW not Merc, dunno why the previous owner sent it there to spray.
Unker - My car not from See&See, its PI.. does it make a difference?
em!!! Cos CnC outsourced their reverse sensor installation to Tomo-Cse for many years.
I won't know if yours is from them.
If your reverse sensor is not from Tomo, not likely they will be bothered unless you want them to instal new ones.
IIRC it's not cheap around $600 inclusive the sensors on the bumper the same color code as your car.
U might wanna try my usual workshop/car accessories
AutoSpritze at 1 Kim Chuan Terrace.
Look for Ah Boon!
Say Mr. Seah refers you!
*faint*
Look for Ah Boon!
Thank you unker!
Please keep me update on your problem :)
Not 100% sure but do try this.
It'd be fuse #61, for control of Remote Tailgate Closing - a 40a fuse. The fuse should be amber in colour.
If the fuse sockets are not numbered, look at the rack of fuses on the extreme left. It would the the 5th fuse from the top.
See if it's blown. A blown fuse is symptomatic of a greater underlying issue. Replace the fuse and try again.
If not blown, plugging it out & reinserting them have worked before. Happened to me on another component in the car.
