Petrol for C180K
woofie
  • Replies 8
Tried both 95, and 98. No diff leh. No guts to go 92 yet :P
looking for an angry fix... "
if u look at the fuel cap, think it said no below 91 ron so i guess 92 is fine, but price different between 92 n 95 not alot
the manual says 91 is okay but only as a temporary measure, and avoid driving at full throttle.
my guess this will cause the engine to ping.. thus u can only use it to jiam si dong.. until u get to find at least 95 and above
At my own opinion, generally the type of fuel used for stock rides is ok..Eg: If the manual stated "no below 91 then 95-98 should be okay de...
However, when it comes to ECU re-mapping mods like Stage I (where the parameters are fine-tuned and upscaled nearer to the limits) or Stage II (Stage I plus additional parts to upscale the car performance), there are specific program codes on using 95 and 98, because for TC engines, the type of combustion on what type fuel plays a part in the compression ratio (Eg: Amount of air vs amount of fuel injected into the combustion chamber). If the wrong type of fuel is used, through long term, it may end up not having the optimum combustion, and hence engine problems.
This is through some lunch-time discussion with my khakees on their Golf GTi Stage I and Beemers Stage I mods....just my two cents worth. :)
