WTS FL W204 W212 AMG Steering wheel
Guest rssid
It will be a complete replacement - steering wheel and airbag module.
looking for an angry fix... "
Could u pm me the price?
mine is e facelift model, so just the steering? i can use back my airbag?
Is it just a simple OBD activation for the paddle shifters or are there new wires to connect?
Hope everything is just a simple plug n play without the need to mod or splice any wires.
Just curious y the Alcantara uses a different airbag module?
Installation method depends on your gear box. If your car is the C180K with the 5-Speed gearbox, the whole dashboard and center armrest console needs to be dismantled. Wiring will run from your gear stick to your steering wheel. If you have the 7G-Tronic, it's much simpler and straight forward, almost like plug and play. Installation isn't as messy although still need some wiring.
Calvin can help you out. PM him.
Or you can try your luck with BENZLINE.
AMG wheel has flattened top and bottom. Same size in other measurements as the stock item.
Plus, it has a much thicker grip compared to the normal wheel.
any assurance that the airbag can still work as it should? heh..
if the airbag doesnt work, rest assured that there will be enough errors for you, the driver, to know :)
  • 7 months later...
