Engine Knocking - Need to use 98?
ping911
My car is 2 years old and done 60k so far. I noticed that there is engine knocking especially when the engine is cold, or if going up slope and I am not revving the engine hard. When I reported the problem to the C&C Service Consultant, he said that I should use 98 once in a while. Is that really needed? Do you guys need to fill up 98 once in a while as well??
I've being using Shell 95 for a long time even my previous near 8 years old stock W212 which clocked near to 200k km
Other than my 1st C Class W203 which I did performance mod, I don't use 98 other than across the border Shell 97.
Think you should go to a "reliable" WS to check the pinking
C180, 7G, turbo, 2013. This was discovered when my cylinder were not firing properly and found the fault to be one of the spark plugs. the ECU also captured pinging in the fault code occasional but NO check light during the ecu scan. My workshop advised me to pump 98 once in a while.
