mods mods and more mods
Guest ladyseals80
  • Replies 118
Hi All,
Mine is a Pre-FL SLK 200, mod so far: Sprint Booster, K&N Air Filter, Spec II plugs, Pulley Kit, full AMG Kit plus AMG exhaust, 19ins rims and car is lowered.
So far mileage for full tank i am able to hit 550km (plus / minus).....
Good morning ACSLK..... all those things you have put in does not literally gulp more fuel... in fact I am sure your throttle feel is lighter, with better plugs and filter, your fuel efficient will be better .... just that your 19"... will feel a bit slow in your start off.... is it light weight rim?
You can upgrade your supercharger and header to make it more racy..... I had that sort of mileage too until i start adding stuff in the car.....
Guest ACSLK
Hi Gene,
Thanks and yes i know about the upgrading of supercharger, header, down-pipe and perhaps the inter-cooler.....my 19ins are not really light weight....but i've since took out the spare tyre as well to reduce some weight...........i've also done a spark plugs enhancer to increase the spark.....
So far so good with what i've done so far, of course can be better!!! By the way what are your mod so far?
Cheers.........
Hi ACSLK.....
my mod is...
Kleemenn K-box, lightweight pulley, K&N filter, 5 bar fuel gauge
Kleemenn header
upgrade to C230 supercharger
AMG muffler
19" Lorinser rim
Bilstein coilover
AMG 6/4 brakes
Vath intercooler
2nd Cat removed
Brisk LGS sparkplug
....... thats all man...... tot of changing the cam shaft ... but nay, not necessary.
Guest Andlee
Wow Gene..thats a lot of mods..must have spend a bomb....but then again.the smile when it brings to ur face when ur floor the pedal is priceless right? :D Sorry for the OT...
Guest ACSLK
Hi ACSLK.....
my mod is...
Kleemenn header
AMG muffler
19" Lorinser rim
Bilstein coilover
AMG 6/4 brakes
Vath intercooler
2nd Cat removed
Brisk LGS sparkplug
Hi Gene,
I'm impressed man.........i am sure there's a lot of power gain....(250hp and 350nm) or more?
Cheers......
Guest Sareve
Hi ACSLK.....
my mod is...
Kleemenn header
AMG muffler
19" Lorinser rim
Bilstein coilover
AMG 6/4 brakes
Vath intercooler
2nd Cat removed
Brisk LGS sparkplug
Wow! You must have felt soooooooooo good after each mod! Especially after flooring the pedal to test out your new power haha. Have you had any passengers complain about ride stiffness after installing your Bilstein coilovers? I have them on my RX-8 and they occasionally make long distance journeys quite uncomfortable.
Guest SgLaKsa
Wow, you guys have seriously modded rides. Mine is just a plain, fully stock 350. Hope to see you guys at the meetups...
Yours is stock but yet its faster leh :punk1: 5.x secs to 100km/hr :bboyspin:
Guest SgLaKsa
Hi ACSLK.....
my mod is...
Kleemenn header
AMG muffler
19" Lorinser rim
Bilstein coilover
AMG 6/4 brakes
Vath intercooler
2nd Cat removed
Brisk LGS sparkplug
:tongue1: Fwahhhh... Xia shi ren ah (scare die people ah)
Guest ACSLK
redhood ]
Hi ACSLK! Welcome to Sgmerc! :welcome:
What are ur onboard figures ' wrote:
Hi Redhood,
What do you meant onboard figures from reset?
Cheers......
Oh, I mean the figure you get on your trip computer. it usually gives two sets of figures. One "from reset" and two "from start". It is probably a more accurate reading than our usual estimation of "number of kms from one full tank".
Hi Redhood,
ok i will check the two figures and check it out........ours are 4pot that's why must mod to feel at least like a 6pot like yours....
Cheers........
Hi Redhood,
Cheers........
I GO WITH THIS VIEW
"mod to go FASTER, must also MOD to STOP EVEN FASTER!!
never just mod to GO FAST and forget to MOD TO STOP EVEN FASTER..."
Guest Sareve
keltanky ]
Hi Redhood,
ok i will check the two figures and check it out........ours are 4pot that' wrote:
I GO WITH THIS VIEW
I think high end carbon ceremic brakes way over kill and the feel is a little binary though. Normal brakes have a sort of progressive braking power, but high end brakes seem to only be "On" or "Off".
Hi ACSLK.....
my mod is...
Kleemenn header
AMG muffler
19" Lorinser rim
Bilstein coilover
AMG 6/4 brakes
Vath intercooler
2nd Cat removed
Brisk LGS sparkplug
Hi Gene,
Cheers......
Yes ACSLK, it's around 255bhp and 350Nm.... with lots of stone chips on the bonnet.
Yes feel very shiok when I start off from 0 or any speed...... like what Kelvintan says must have fast stopping power ...... Before you start any mod, I would suggest to burn the first hole in the pocket..... by installing the AMG brakes..... I did it the wrong way and do the Kleemenn kit and header then i feel the stock brake really soft and longer distance to stop.... I am sure most of the guys can atest to it. So after the brake then i feel more secure and I put in the supercharger next. No problem in the stopping power... shorter braking distance than stock.
So with all this mods and power and the consumption is 11.6 or 11.8(town).... I am happy man. :clap:
Hi ACSLK.....
my mod is...
Kleemenn header
AMG muffler
19" Lorinser rim
Bilstein coilover
AMG 6/4 brakes
Vath intercooler
2nd Cat removed
Brisk LGS sparkplug
Yes Sareve,
The coilover lowered the car to 2 fingers gap and the right comfort setting can be set from 0 to 9.(I think the bigger the number the more uncomfortable you feel)... I set to the lowest and still cannot accept it...... but Kelvin(MBM) further make some setting on the top of the suspension and now the ride is comfortable, still can make tight corners.
Guest ACSLK
Hi Gene,
Did you do a ECU re-map? Did you install sway bar? and also true 0 to 100 (fast) 100 to 0 (Must be very very very fast)...........
Solid mod you have man..........is yours also a pre FL model (R171)
Cheers..............
Hi Gene,
Please dont do the re-map thingy.... piggy back is still safe... one of the guy had a really bad experience with it
I did not install sway bar
what to you is fast?..... lets just say that it fast enough to give you stone chip on your bonnet(how many ppl have stone chip on their bonnet?... ;D..... and stop in time to avoid many accident. :clap:
Joke aside... it is thru stage by stage mod, I learn more and more about 'him' and you will be happy when you see 'him' mature :yumyum:
My is prefacelift... Sept 2005
Guest ACSLK
Hi Gene,
Hi Gene,
I not so sure about piggybag for Merc but for Bimmer i do know there's a few brand.....
Cheers...
So far I heard about BMW ECU Flash are more reliable..... But I didn't touch my 523i.... just want it to be a quiet and comfort ride....
Somehow what I heard ppl reflask their ECU for Merc tends to have problems.... Anybody can share their experience on this?????
Guest ACSLK
Hi Gene,
Yes BMW re-flash is more reliable, i've tried re-flash and piggybag to my bimmer as well (it works well).....but only worried about Merc that's why i've done so, probably like you say (piggybag).....
Thanks......
Guest ACSLK
Read in another forum that Kleeman developing supercharger for SLK350 that will pump up performance to 400bhp! :clap:
Hi Redhood,
wow 400bhp.....go for it man.........
Cheers......
