White & Black Part 2
JIN
Hi, here's the progress thus far.
Original Thread Found Here :
I got rid of my mirroring and added CarPlay as I wanted the resolution to be consistent.
IMG_2551
IMG_9404
IMG_9405
I also decided to change location of my dash cam so that it doesn't block me.
Original Position
IMG_2552
New Position - Not visible from Driver's view.
IMG_2553
IMG_2554
I also added a black strip to where the mounting point was. This is so that it looks almost stock from the front, and doesn't expose the double sided tape.
IMG_2564
Bought these rear license plate bulbs to have the same consistency in 'whiteness' since all my other bulbs have been changed to white leds.
IMG_2560
And decided to get another front emblem to try the all blacked out look.
IMG_2550
My only cosmetic upgrade that I really yearn for were the LED lamps, and I finally took the plunge.
IMG_2557
15036429_1528935180454954_6675051203937413576_n
IMG_2559
16174466_1619593668055771_1020811921606887445_n
IMG_2558
These are not plug and play. They need coding. As I was one of the first guy here to get them retrofitted, the shop took more than a day to get the codes right.
I prefer the rear lights as they now look more symmetrical. It has a slightly sleeker / modern look ( though I missed the butterfly look ).
The fronts are amazing. Its now whiter, including front white led high beams.
The other issue I had were of the dynamica from the steering wheel. Despite me almost never touching those two areas for the entire year, it still started to fade out.
IMG_2547
Also the OCD part of me couldn't stand that the red stitching were not ... perfect.
IMG_2549
11 hours ago, petetherock said:
Did you have to remove the steering wheel to do the stitching bro?
I had to remove the steering wheel as they had to replace the alcantara / plastic portions with carbon.
However they gave me a replacement steering wheel while they were working, takes them 1 - 2 weeks.
  • 6 months later...
  • 3 years later...
  • 3 months later...
On 6/21/2017 at 6:21 PM, JIN said:
Got these from the local Autobacs.
IMG_2540
IMG_2546
hi... sorry to revisit this old thread. but what does this do? I just got myself a preowned X253 and noticed some wind noise at 100km/h on expressway. i was thinking if this could solve it.
On 6/21/2017 at 6:22 PM, JIN said:
And these from aliexpress :
IMG_2405
Honestly, the fitment was perfect. I should have done this way earlier.
IMG_2538
and what does this do? thank you
