Run Flat Vs Normal tyres
paralleluni
Good day to all,
Would like to enquire from the members down here on your views. Im currently running on Run Flats. Come stock from C&C.
For Run Flat Vs Normal tyres, I understand that most folks would support Normal tyres.
A member previously mentioned to just simply fit up a TPMS to monitor pressure, get remedy before it goes totally flat. Or get a patch up equipment for tyres from Autobacs. Also noted feedback that FC suffers with Run Flat and that they are more ex than normal tyres.
->But I have tried both Run flat and normal tyres previously and the FC diff is minimal. - Appreciate comments from bros here on their experience
->One of my friends got a tyre puncture but was not fully deflated (approx 75percent with air). Drove approx 5km and by the time he reached the tyre shop, his rim was damaged and he spent money to change to a new set (diff design). It was stock rim so heart not so pain. Question is for bros who change to expensive rims ($4k ++), if you are running on normal tyres, when there is a puncture, would you not risk getting that rim damaged permanently? Run Flats can still protect the rim for a minimum distance of approx 50km. - Appreciate comments
Thanks all.
  • Replies 6
Puncture can cause a rim damage? Care to share more details?
I had driven both Run flat and normal tyre . Based on my opinion .
Run flat
Can still drive up to 100km on 80km/h while it's flat (more than enough for u to run far)
More bumpy ride
Shorter lifetime (max I heard was 40k km)
Normal tyre
Have to patch / replace tyre when it's flat
Comfortable
Last longer( some claims their tyre can last 80-90k) I ever had one tyre set lasted me 100k km with still 10% thread
Might be able to repair
Perimeter of the rim got bent. the part closest to the road.
Sgp so small and tyres shop everywhere .. to damage a rim even though puncture, the driver has to be quite careless or simply finding reason to change rims
for me .. It will be normal tyres.
RF too hard, noisy and expensive.
To be safe a tyre inflation kit will be handy .. but if just a small puncture it shld be able to get u to the nearest tyre shop without using it.
But if worry then stick to RF lor
Run flat
More bumpy ride
Normal tyre
Comfortable
Thanks for the input bro.
