W204 (Year 2009)- Headlight (OEM) replacement
Spincer
Hi ,
For info and reference.
Just replaced a new pair of headlight (OEM) at Chip Soon due to one of the bulb damaged which link to the insulation cable which was one of the common problem for W204 as shared by experts. (Heard that original pc is S$540 x 2 = S$1080)
S$320 x 2 = S$640 (OEM Headlight)
S$120 (Labour)
= S$760 for one set.
Thanks
  • Replies 9
You can replace the wire harness (cable) instead of changing the entire headlight set. This option will be cheaper.
  • 6 years later...
