Rattling at D
Varero
The FL C180 is a new engine ride. So not surprise that See&See is try n error TS.
What disappoints me Is that they will comment that U r the first ride that show this provlem. Then they check your ride and comment U mod your ride here n there. Maybe this mod cause the noises.
Victoria Concordia Crescit
I too had a rattle while the gearbox is on D. Sound like something is knocking the undercarriage. Found out that my gearbox mount was damaged. The rubber had slacked and it's almost resting at the bottom of the inner rubber.
From looking on outside, it doesn't look damaged or any difference. But once it's removed, it's pretty obvious.
Might be a place to start looking and the gearbox mount is fairly cheap.
I paid $90 supplied and fitted.
Good luck
Bros,last month change gear box mounting n yesterday change engine mounting. Still rattle but less frequent. Now at a loss as dont know wat need to change. Could it be relating to the software? Really at a loss.
Good luck
Hi where did you change yours and how much, if not convenient please pm me. Thank you.
Maybe you re bring the ride to c&c workshop and ask for their advice
