headlight issue
dankriscurly
But when u adjust it.does both left and right move together?
As when i sent in for servicing c&c say its not common and should be balanced
Will need to sent in to do a check and repair...
I hope they are not wasting my time if its supposed to that way...
I doubt so as e left is way too high and hit oncoming vehicle, could blind them
check if your headlight has a buzzing sound on the left. I just got mine changed under warranty. It does produce a buzzing sound and the headlight is vibrating that is caused by faulty motor in the headlight unit which require to change the whole headlight assembly
Nope my experience was I turn on battery mode without starting the engine, turn on the headlight and can only hear when I was at the engine bay but not inside the cabin
Hey MB has confirmed the left headlamp unit is faulty as the linkage (dunno wats that) has mulfunction!
Spent 1 day to order in new left headlight (completed set) and fixed up the next day...
Now its balanced and able to move (left & right) together when i adjust e positioning...
I was wondering why ex owner didnt even notice this obvious headlamp issue?
It was shining into direct into oncoming traffic!
Luckily still under warranty :)
Lucky you, mine took 3 full days! Anyway headlight might not be a obvious issue to some as they wont notice the difference except for blown bulb
