2015 FL B-Class
denwee
It really depends on what you want.
Performance and comfort for the 2 cars will the same no matter which variant you chooses. 17" and 16" dun make the driving any more spirited, as the car height itself will the the main factor in cornering (not to say that the cornering is no good, just that don't try to drive like a sports car).
My recommendations as below:
a. Only looks better in 17", but doesn't make the car itself any much better to drive.
b. Although it will feel much classy with a leather wrapped steering wheel, the molded original steering wheel itself is not bad too, the perorated pattern on the steering wheel extends throughout the steering wheel that is so easy to grip.
c. This might be the only consideration whether you want to spend 7K on this as this is the only item that cannot be changed easily, though it still doesn't make the car much faster.
I intend to go buy chrome stickers that can emulate the same effects as a C180, which only outlines the exhaust pipes without the actual twin pipes showing.
Thanks SilverKris for the advise. Very helpful for my decision making.
I have to admit, this must be the BEST accessories you can have on your B Class.
Anyone know where to order this?
http://youtu.be/uPzn3V-NSi4
Less those externally mounted, those mounted inside the vehicle are all available in eBay, Amazon or TB and they deliver to SG.
Below are examples, now u know where to get... buy, mount and use if u dare
I have changed to comfort based sports tyres on the first day (traded in the run flats). Don't find the road noise intrusive.
But the B-Class does have a rather rough engine, unlike typical smooth running C-class engines.
But as engines are concerned, I rather have a rough but reliable one that one that breaks down often.
is the FOC Optic Huper solar film provided by C&C good at shielding sun heat and UV? My office is open carpark and so worried about the performance of the solar film in shielding from the sun.
Cnc FOC solar film is normal one doesn't prevent sun heat one. You need to do aftermkt ones..
