Workshop recommendation Flushing Brake Fluid
  • Replies 14
Flushing brake fluid? From the hose or the container? The former by bleeding not flushing to prevent air lock and the latter is by topping up. Flushing of gear box and engine oil is a norm. Isnt it is better for them or workshop guys to test it after installation? this is to yr advantage. What if the brake mechanism fail??
Pee por pee por......
Post yr making of E63 pictures hor. Mia pee por pee por.
Haven't collect car yet.... will shoot some pro pictures with my SIII on tripod to show u....
Don't forget to use your long range tactical nuclear strobe light for that crisp, clear photo.
- Albert Camus
I go borrow from Edwin. ..
Bxxbs I cannot accept. . Like holding 2 water bomb..... dunno when will explode. ....
The silicone implants now are made from solid gel. So even if they rupture, there is no liquid to leak out.
Change brake fluid at Espace. Use Castrol SRF: Maximum overkill.
Wet boiling point of 518ºF.
- Albert Camus
Wonder hows the feeling ... no more sagging i suppose
