W220 Headlamp
thaiedwin
my S280L W220 left headlight, low beam area melted. I still does not know what had caused it. Does anyone know where is the cheapest replacement? 2nd hand or new?
  • Replies 11
Any workshop will able to get it replace for u if only the bulb is malfunction. However if the bulb got stuck or melted and damage the fitting then the issue is not as straight foward just by changing the bulb. Picture will be good if you have it and post it here.
Its not the light bulb but the lamp. I will post pictures tonight.
The lamp? Not headlights?? hmm Ok pictures will be good.
here it goes.... can u see the thing dangling at the low beam area?
Yea, cant really figure out what is the ring for etc. Here is yr options, change the entire cluster (new (local distributor) or used - Propel) or go to those workshop that zhng angel eye ask them to pry open the headlight and reattached the "ring" and seal it back. Yes i know some of u got phobia (not ah pui piglet name hor) of water seepage etc this concern is uncalled for coz i had jad zhng couple of headlight on my previous car and no issue at all. I might be wrong again!!
The Ring is part of the low beam, well i wonder why it melted bring to C&C quote was 1.5k and bring to workshop le 1k all in.... They said the ring melted no choice has to change the whole thing.
DRL is? sorry not so familiar with all these terms
DayLight Running Light!!
