Mercedes Wheel Fitment Guide
Submitted by millionmilebenz :-
Hi all!
I recently changed my tyres and I think the following site is the most comprehensive guide ever on tyres (and rims). Everything that is possibly related to tyres seem to be covered.
Ever wondered what all those numbers on the tyres mean? (see page 1) How about camber/toe/caster adjustments?? (see page 2 for advanced topics). Read through it patiently and I guarantee you'll learn a lot... Enjoy!
http://www.carbibles.com/tyre_bible.html
Share this post
Link to post
Guest S300L
Hi Everyone,
I'm new to this forum. Any idea what the PCD is for the current S class?
Appreciate the help!
Share this post
Link to post
Guest airilqudshi
Hello Guys
Does the new AMG 18 inch wheels for W204 can be fitted into the old W203? ???
many thanks
Share this post
Link to post
Guest noelhon
To all Bros,
For W124 8v, what is the maximum rim size i can go without touching inside the wall when turning full circle??
Am thinking of either 16" or 17" width 205. I dont know how to use the AR.
Thanks in advance for advice :pray:
Share this post
Link to post
benico wrote:
Can W204 original rim and tyres with W203?
Offset is it the same? Ask the tyres shop guys.
Share this post
Link to post
Guest fatrat2
... so, which tyre does the speedometer read from? Front or rear? or neither cos the sensor is at the tranny? For Mercs??
Share this post
Link to post
Hi guys jus wanna check my w204 fl currently on h&r sport springs, will it fit a bbs 19x8.5j et32 rims?
Share this post
Link to post
http://www.automobile-catalog.com/ will tell you what alternate tyre sizes you can run on your specific model, and www.tyrerack.com will let you try on various wheel combos that are known to fit, and you can see how they look on your car. It's a game I've spent many nights playing in the past lol
Share this post
Link to post
Hello bro, 8.5j with ET32 for front sure bang fender, for rear lagi worse. Maximum offset you can go with 8.5j is ET40.
Share this post
Link to post
Hi all,
think its safer to have customed made rims right? Customed made cant go wrong....take away all the spacers etc...
Share this post
Link to post
Went to a tyre shop and kenna told off by the boss saying my current wheel offset profile doesnt match my model. Im driving an 07 w211 on 17inch rims, the type mostly seen on w204s. Tire profile size is 225/50/r17.
Is there anything wrong with this wheel profile? Im quite worried now.
Share this post
Link to post
Do you have any rubbing issues with the fender? Try doing full lock u-turn , and drive over humps to see if there are any knocking or running sounds.
If there is no sound then you should be fine.
Share this post
Link to post
I dun hear any rubbing sounds. But i did experience knocking sounds at random times when gg over humps. My mech told me it is the shock absorbers. Haven tried the u turn experiment yet though.
Share this post
Link to post
Bro, did the tyre shop boss tell which is the correct size? IIRC, should be 225/45 R17 cos I have since changed to 18" shoes!
Share this post
Link to post
Should be absorbers or worn bushes!
Share this post
Link to post
I went for a 2nd opinion at another tyre shop at upper serangoon road. He mentioned that there should be no problem as my rims are original stock mercedes rims for c/e class. He did mentioned that my tyres should be 245/45/r17 instead of 225/50/r17, which is funny cause logically 245 is wider than 225. Wouldn't that make my tyres going more inward to the wheel bay? lol...
Share this post
Link to post
Better keep it simple n safe, also save money,,.upsize isn't as simple as u see. The mechanism inside hv to change accordingly to meet the bigger size too..German dun design a car which can fit mod to better the characteristics which they spent years to developed, test n test before going into mass production, if any Tom n jerry can enhance the performance with easy job, then merc technical team can retire early. Anyway, standard spec already outstanding amongst the norms.
Share this post
Link to post
