dteng75
C43 Rims on W205 and W205 Stability
First of all, I apologize that I don't contribute much as I'm quite quiet in forum. Not used to comment as I'm quite noob and not very active online. I have some questions and hope to have some comments.
I'm bought a 2nd hand C200 W205 AMG styling. Wheel specs are Front : 7.5Jx18 ET44, Rear 8.5Jx18 ET49 staggered setup. One of the rim warp as previous owner didn't take care. I managed to find C43 AMG rim with this setup
Front Wheels: 7.5Jx18 ET33
Rear Wheels: 8.5Jx18 ET49 (no change from current setup)
I have installed and it looks fine. Front was flush. Looks more sporty. I have look thru many web sites and recommendation was 245/40R18. Can I use 255/40R18 on the rear? I hope to make it more flush and improve stability or should I use Wheel Spacer? I can't seems to find any info on this but not sure if any bros can advise.
Share this post
Link to post
Using the 255/40 over the 245/40, you will get a pretty straight looking sidewall as opposed to a rounded one.
For wheel spacers, most will advise you not to use it as it may create issues like vibrations...
but if you intend to, look for hub-centric ones. the thinest hub centric spacer should be 12mm.
I would not advise doing both. using a 12mm spacer to protrude the wheel and using 255/40 which straightens the sidewall, you may encounter fender rubbing.
Share this post
Link to post
Hi dagger,
Thanks for your advise. Btw, what's the issue with Straight looking sidewall as opposed to rounded one?
Share this post
Link to post
