W205 New Car servicing intervals
PearlJam
I wish to know from new W205 car owners, car bought from C&C:
Is there a 3'000km or 5'000km free servicing?
Or when is the first servicing?  25'000 km?
Typically how much will it cost?
What item is worth buying from the boutique to utilise the $3'000 service credit?
Thanks for any info.
I'm not sure about W205 but I serviced my W204 at 15000km, Service A and it's chargeable. Never heard of free servicing by C&C.
Based on my own experience, the only worthwhile use of the service credits is for servicing. Anything else (i.e reverse camera, integrated GPS, grooming, etc.), C&C charge a bomb and it'll be much cheaper and sometimes even better results to get whatever you need done outside.
W205 servicing interval is 15,000. Around 13k the car will prompt you to get ready to service your ride.
It's all pre-programmed. Best to use your services credit for servicing.
15k servicing is around $400. 30k servicing is around $1.1k.
30k so exp? What about the next one 45k?
Yes. It's that ex. Plus you've got to leave your car overnight for 30000km service aka B Servicing. 45000km service is normal A service but when you reach 60000km which is B+ Servicing, it'll cost even more than the normal B Service. All these excluding wear and tear items like tyres, brake pads, engine and gear box mounting, etc.
What extra servicing does B include?
Full Maintenance
(Assyst Plus Service B+)
Every 3 years / 60,000km intervals, whichever comes first.
Lubricants and Parts Replacement
1. Fully synthetic engine oil
2. Engine oil filter
3. Brake fluid (drain, replace, bleed)
4. Air filter
5. Dust filter
6. Coolant
7. Auto transmission fluid
8. Auto transmission fluid filter
9. Fuel filter*
10. Spark plugs*
Check and Top-up
1. Fluid level of windshield washer
2. Fluid level of power steering
3. Tyre pressure, including spare tyre
4. Fluid level of rear window washer system*
5. Radiator coolant level
6. Radiator coolant/water ratio
7. Brake fluid level
8. Transmission fluid level
Electrics
1. Assyst system reset
2. Control units function check with Star Diagnosis
3. Horn function and operation checks
4. Windshield wiper function and operation checks
5. Headlamp wiper function and operation checks*
6. Rear window wiper function and operation checks*
7. Central locking function and operation checks
8. Closing assist function and operation checks*
9. Battery load test+
10. Alternator performance test+
Lights
1. Hazard warning signal function and operation checks
2. Turn indicators function and operation checks
3. Indicator lamps, symbol function and operation checks
4. Front and rear lamps function and operation checks
Tyres and Rims
1. Tyres condition checks
2. Alloy rims condition checks (only upon wheel rotation)
3. Rim bolts condition checks (only upon wheel rotation)
4. All tyres dynamic balance+
5. All wheels rotate+
Engine
1. Engine compartment wash+
2. Engine V-belt condition checks
3. Major components leakage checks
4. Check chafing, routing of lines and damaged components
5. Exhaust system checks
6. Engine mounting condition checks
Brakes
1. Front brake pads overall thickness checks
2. Rear brake pads overall thickness checks
3. Brake efficiency check using brake roller
4. Parking brake function checks
Others
1. Windshield wiper blade condition checks
2. Windshield wiper spray nozzles condition checks
3. Headlamp wiper spray nozzles condition checks*
4. Rear window wiper blade condition checks*
5. Rear headlamp wiper spray nozzles condition checks*
6. Seat belt condition checks
7. Major components leakage checks
8. Check chafing, routing of lines and damaged components
9. Front suspension joints condition checks
10. Track rod and drag link joints condition checks
11. Body check for damages
12. Chassis, body components check for damage and corrosion
13. Paint condition checks
14. Door and lid catches condition checks
15. Gearbox mounting condition checks
16. Propeller shaft companion plates condition checks
Full Maintenance
4. Air filter
5. Dust filter
6. Coolant
9. Fuel filter*
10. Spark plugs*
Check and Top-up
Electrics
Lights
Tyres and Rims
Engine
Brakes
Others
Went down C&C to replace my fan belt FOC (still under warranty), due to squeaky sound during cold start.
my SA told me, 60k km B+ service will cost ard sgd 2k plus.
dunno how much they will charge if some other parts needs to be replace?
Usually by the time you're due for B+ servicing, your warranty would have ended. Go to any reputable workshop for servicing.
this SA told me to get the package while doing B+ servicing, meaning on top of B+ servicing, they will add another 2 more normal servicing.
it will cost ard 2,5k for total 3 servicing (incl B+).
worth onot?
worth onot?
peace of mind service from cnc -> yes.
$2.5k can service at outside workshop many times.
depends on own preference. :)
Warranty ended, pay premium for AD is just a name. Many reputable workshops outside can do an equivalently good job, have better diagnostic tools, and shorter downtime. Half a day for outside workshops compared to 2 days at AD.
As darksaint mentioned. $2.5k can service your car many times over with outside workshop compared to a B+ and two A services.
Not sure if outside reputable workshops whether they let us bring our own parts (original parts from golden link) to do servicing onot? afraid they might not entertain us...
U can call to check with them. :)
I bring my own parts from golden link to MBM.
  • 1 year later...
1 hour ago, Omgamg said:
If my w205 only clocked 25km but the system keep prompting me to do service B cos my car is 2 years old, should I wait until 30k?
last servicing is at 15K? maybe can do it at 27K?
i normally service at 10K to 12K interval as SG traffic too many start stop and hot weather.
  • 1 year later...
I went down for my 45,000km servicing today, and probably my last servicing before the warranty is over.
I was surprised when they told me that they do engine flush and engine addictive for every engine oil change.
Was also informed that my transmission train software is not uploaded which they will update into the car; was quite surprised to know this as well.
