Any comment on this RIM?
  • Replies 8
Guest kopimonster
altho BBS got forged rims, if i am not wrong, the one in the pic is BBS CH rim, cast iron type, weights ard 24/24.5lbs (ard 10.9kg) depending on whether its 18 X 8.0 or 8.5. if for rough use, i suppose its ok lor, unless you extreme sort, wana optimized the weight of ur car, only then, you might wana go for the more expensive forged rims lor.
