Help needed - Can't manual open my Boot
iankaw
As i will be travelling for 5 days, i ve been advised by workshop to remove the batt connector from the boot because there is a red error message showing Battery symbol. He was worrying 'something' else may drain my new batt flat. After removed one of the connector and closed the boot door, now i cannot open it, not even with the metal key from the remote unit.
Did i miss anything? any advise? (:
  • Replies 4
Did u hook up the connector? If not there are no power source.
I had a similar problem lately but it was due to a failed central locking pump and seized lock cylinders for all locks. I called various locksmiths and all were unable to open the car. In the end I had to contact a repo tow truck driver and he had the tools to do it. They will wedge an airbag between your door and pump it up to get a small opening. They would then insert a long metal rod to pull the door handle open. There was slight damage to the paint as he had to pull really hard on my car to open the door(his hand had a small cut and blood was flowing out by the time he opened the door). All in $80 bucks which was high but no choice as I was stuck by the road on a Sunday morning. Hope you have better luck.
