Blackvue DR400G problem
Guest apman
Guest apman
Installed it last night, went out for a spin to get some recording and at the same time hope to set the angle right. This morning plug the card in and here is my findings;
1. The vertical angle is OK but the horizontal angle captured more right side view then left, off center, anyone encounter this before and how to tilt it ? I installed the unit in such a way that the camera lens is at the center of windscreen, the mounting base is off center towards the right side, maybe due to the slight curvature of the windscreen it is only natural that the lens now point more toward the right side.
2. Playback : the first 20 sec out of the 1 min recording is always jerky, anybody encounter this before ?
3. Date/Time/ GPS : I was told once the unit is ON it will automatically update the date and time via GPS, my unit show year 2010 after some recording last night, there is no display of speed and location, so my GPS is OFF ? I flip over the software but couldn't find a GPS on/off selection , hidden somewhere ?
Appreciate your input...Thank you in advance.
  • Replies 23
Guest manmerlion
Bro
1. I suspect the lens is off-center. I believe through trial and error, you should get the angle and alignment right. The guy who installed my Blackvue used the reverse camera to set the camera.
2. Try upgrading the firmware. The current version is V1.037. Download from http://www.blackvue.com.sg/download.html
3. I suspect your region setting is incorrect. Set it to Singapore. Speed and location display can be set from the software that comes with the micro-SD card.
Good luck!
Guest apman
Thanks for the information. Firmware already V1.037, region also set to Singapore, now try to format the SD card and see how, the first time I power up the unit was without GPS signal ( indoor ), wonder if this is the reason. Try my luck again.
Guest markcwq
When indoors, the satellite signals are blocked so you will not have any GPS signals. Once you move your car out into the open, the GPS would be able to acquire the satellite signal and give you proper readings. However, just like any other GPS units, it'll take sometime to acquire the correct signals when you turn on the device for the first time. Subsequently, it should be a lot faster.
Have been using my BlackVue now for almost two weeks. No issues with it so far.
Guest apman
Not so sure if the time setting program work on the DR400G, which obtain time / date via GPS...anyway let me see if the GPS work or not if not then I try the time setting program. Actually I don't want the file to show speed, just date and time enough, sure most bro here feel the same hehe..
Go download the card formater software from Pittasoft website.
Do a full overwrite formatting!
For 16gb will take some hrs to complete for a full format.
The latest software is version 1.038.
After format & update software, reconfig your settings & save your settings.
Go to your car with the card & wait for it to reboot & for the software update to take effect.
Drive a few rounds to see if your GPS is working.
If it's working, the gps light on the Blackvue will be lighted up.
I m on software 1.037 for both my DR400G and running happily for many mths now.
Guest mvdennis
unker i'm just wondering if you leave yours to record on park mode too?
My front on a 32gb card records in Parking mode for 6 hrs.
IMHO running a battery below 12V not very "healthy" if U want your car battery to last longer.
My rear on 16gb, I don't do recording as usually my Kar chng is backup to the wall :)
Guest apman
Been there done that le, formatted the card, reload V1.037, reboot, still no GPS signal after driving for 30min, I even extend the unit out of the car for 5 min, just to rule out my solar film is not the culprit. Now I know why le, I'm just suay to have a faulty unit that's it.
Guest benico
Been there done that le' date=' formatted the card, reload V1.037, reboot, still no GPS signal after driving for 30min, I even extend the unit out of the car for 5 min, just to rule out my solar film is not the culprit. Now I know why le, I'm just suay to have a faulty unit that's it.[/quote']
Bro, check with supplier... see if can resolve or not...
Guest apman
Anyone using Finevu CR-300HD ? 5m pixel cam no GPS, consume less power with built in cut-off when battery fell below certain voltage. Price is higher than Blackvue, about $400. I don't quite like the video quality of Blackvue, wonder if the 5m pixel helps.
Oh yes, the time setting program does work on DR400G.
hi where did you get your findvuve what is the damage like? isit able to hide behind the rear mirror? thanks
wow seems like not so cheap i got a quote for e old blackvuve dr 350 at abt 250 plus installtion
ah boon actually recommended this model over the 400 as it's not as hot. different strokes for different folks, i guess.
looking for an angry fix... "
same here, i've only had the card issue due to heat twice since installing it nearly 3 months ago
