Sunglasses holder for W204
Guest jtang
  • Replies 81
Guest Yap ST
Bro,
U willneed to go down make the order and make the payment before they place order for you.
Address: 209 Pandan Gardens
5 day work week
Closed at lunch 1230 - 1330 hrs
Tel: 65684631/2
Mr Gilbert
Guest 6008
Yap ST wrote:
bro extra6,
Have u collected ur Sunglass holder? I had mine and had fixed up... swee swee heeeee
:whistle::bounce:
Bro . Post pics to show leh . :becky:
Guest jtang
what's the part number for this to match greyish white roof trimming?[/
7E94 grey
8K67 buckskin (brown???)
8N96 beige
9051 black
__________________
Guest extra6
Yap ST wrote:
bro extra6,
:whistle::bounce:
Bro Yap, just collected it yesterday but do not have the tools then to fix it. Will do so today.
Guest jtang
MrsGoh wrote:
So far all for driver's side? Anyone fix on passenger side? Should be the same right?
Yes! It's the same...Tell Mr.Goh to order 2pcs:becky:.
Guest kreampuff
Yap ST wrote:
Bro,
5 day work week
Tel: 65684631/2
Mr Gilbert
Went down to order but realised it was a waste of time as I can use my service credits to pay for the item...so could have done it by phone.
Guest Yap ST
Bro if by Phone u will not be issue with any order confirmatio right?
Guest dudemobile
I got the clips out but the handle is still stuck and am not sure how to get the handle out. Did you use the L shape metal piece to pry the handles out as well?
Tried using a flat head small screwdriver to press the latches but cannot budge la. Paiseh, but if only your metal clip works, I might need your professional assistance. Kopi/teh/Milo Peng on me.
Guest Yap ST
Bro where do u stay? Or w r u now?
Guest kreampuff
Just installed mine too.
My unofficial instructions for removal
Tools required - narrow flathead screw driver
1. Pull down handle to expose plastic clips. Insert flathead screw driver into slot and twist or pry out plastic clips. They should be pulled out almost vertically towards you, assuming you are sitting in driver seat. Try not to damage the clips as you will need to use the same clips for your sunglass holder.
2. After removing both clips, time to remove handle. Instead of using all your strength to yank the handle down towards you by pulling on it, use your right palm to PUSH UP the base of the handle and at the same time, use your left hand to pull on the handle with a strong steady pressure. The handle should come out without having to use hulk strength.
3. Snap in the sunglass holder, push in the clips and viola, done.
Please note, I am not a professional and the above instructions should be used at your own risk. I'm just sharing what worked for my own vehicle.
Anyone wants to buy a grey C204 grab handle?:bounce:
Guest Yap ST
Bro u sound like pro man... U work in C n C?
Hahah
Guest kreampuff
Hahah
No lah, but sharing is caring.
I was hoping to find some instructions online before I started but couldn't do so, so posted my own instructions after I managed to pull the handle out.
But I have to say the positioning of the holder is a bit awkward as it is behind your head. Taking your sunglasses out while driving or putting it in can be a bit dangerous, compared to other car models where the holder is in the centre middle.
That's becos this was designed as an afterthought from customers' complaints. It's cheaper to produce this instead of redesigning a whole new roof console.
