Pirelli P6000 Powergy
Guest mr w124
My usual - 32psi rear 30psi front running 225/45/17. Maybe you'd like to try out different combinations and fine tune to your desired levels.
I try to check pressure once every 2 weeks at the nearest petrol station from home(cold start) for a more accurate reading.
Guest RRRoaring
Get a digital tyre pressure meter and I have been using Nitrogen in my tyres for some time now. This is available from Stamford Tyre Outlets. There are quite a few advantages in using Nitrogen since it does not corrode the rubber valves and tyre rubber itself and also leaks out a lot slower than normal air. You will initially find the ride a little softer as it is more inert than compressed air and does not expand with heat as much too. Check it out ! BTW. All F1 tyres are inflated with pure Nitrogen...... must be a reason behind this.
