Lowering Guide for W124
g8crasher
[Excerpt from another thread]
I've tried looking for a camber kit locally but can't seem to find one. Might have to resort to US made camber arms which should set you back about US$300-400 plus shipping. The other alternative is to order from www.k-mac.com.au but their system is more of an adjustable bushing kit and the rather high exchange rate is not exactly favourable.
You'd probably require a rear camber kit more than the front if you're going for a standard lowering height of between 30-40mm which is the average achievable height from using H&R, Vogtland, Eibach springs.
You can also order different spring pads to adjust ride height. I rang Premier Auto Parts Pte Ltd and they have OEM spring pads. The W201 spring pads will fit the W124.
Front Spring Pad Part #
201.321.09.84 8mm
201.321.10.84 13mm
201.321.11.84 18mm
201.321.12.84 23mm
Rear Spring Pad Part #
201.325.09.44 8mm
201.325.10.44 13mm
201.325.11.44 18mm
Please add more information as you see fit.
