Anyone has experince of a leaking roof in their SLK?
Guest blackknight
  • Replies 5
Guest stealth123
blackknight wrote:
Anyone can share the concerns and the solution?
Read in SLK world forum that some SLK owners have this rubber seal problem
hmm.. mine is not exactly a leak.. but when the car wash uses a water jet... water can come thru the window...
blackknight wrote:
whats the solution? solve?
Dont go high pressure jet car wash....
Dont drive it out during raining days....
Dont bother just drive it, SLK should be driven top down.
Could be rubber seal or roof alignment is out BUT remember the golden rule, try to exercise the hydraulic rams of your roof every now and then.
The rubber seal where it meets the windscreen will benefit from movement too especially if one parks under the sun otherwise you'll find it tends to "stick".
:whistle: Topless is the way to go or... manual roof types are great :P
