Any W124 with lowered spring?
Guest sirBenz
  • Replies 5
sirBenz wrote:
As above anyone running on a lowered spring?
My old girl (sold last July) was on eibach pro kit springs. Ran perfectly fine with stock bilstein shocks. H&R springs sit slightly lower. You may adjust the ride height further by altering the thickness of the rubber spring pads. Do a search in the forums and you will be able to find the part no.s for the spring pads.
Guest sirBenz
hey Leon,
Thks for the info, I've been offered $500 for Eibach PK w/o installation, any comment on the price? btw how much and where did u got yours from? and how hard was the ride on the scale 1-10 with Eibach PK? Currently I'm running stock springs with dot1 rubber. Planning to setup my ride 1dot front and 2dot rear with E PK.
Mike wrote:
1 dot front 2 dot rear will leave the car too low i guess. leon wat padding no. did u used front back
Low swee lah. I used 2 and 3 too high leow. I told sirbenz to use 1 hehehehe.
