Air-con maintainance
Guest Merc-C
Hi guys,
My car aircon has a foul smell every morning upon start up, but once I drive off after awile the smell is gone.
Think need to go for some aircon cleaning, any good place to recommend?
TIA!!! :)
  • Replies 8
Turn the temperature dial all the way to the hottest setting, recirc off, fan speed on full blast. Get out of the car and let it run for at least 3-5mins. The smell should go away. You have to do it dilligently at least once a week.
Thanks bro,
Will try it out. :)
Had the same issue with my w204 - horrible smell almost every day for about 30-60seconds. Eventually, Pandan loop people re-programmed the AC control to dry the system. Been several months and almost no smell. If in warranty, give it a shot with your service advisor.
Thanks bro,
No more warranty so gotta find other means to resolve :)
Just to update,
Went to my regular air-con guy to check it out.
He did some checks, pumped gas and changed the filter.
Next day when I started my car, no more smell! :)
Problem solved! :)
