need help with headunit
Guest eokh
Howdy !!
have a semi-new HU from one of my prev cars sitting on the shelves doing nothing
recently having a bit more time on my hands
had been trying to rip out my old single disc HU and replacing it with this semi-new one
somehow i simply cannot pull out the old HU
why ??
is there any other mounting screws at the back that i need to remove ??
i had been looking around the foot well area but could not find any access points to access the back of the HU
does any folks have any kind advise for this poor sob ?
many thanks in adv !!
Have you tried the usual methods ?
Method 1
Cut 2 strips of wire (can be made from wire type clothes hangers) and insert on either side of the head unit approx somewhere in the middle in between the metal sleeve and the head unit. Push the wire till you hear a click or observe that the head unit is "ejecting" out of the metal sleeve surrounding it.
Method 2
Involves prying the carpet and trim tucked under the side of center console panel. You will see an air vent located just below the right side of the glove compartment. Pry the carpet away followed by the trim board from underneath the side of the center console panel.
If you carefully squeeze your hand through that gap created by prying the carpet and trim panel, you will be able to feel the rear end of the head unit. If you're lucky enough, a little push may be able to get your head unit to eject from the metal sleeve, allowing you to pull the unit out.
Do it slowly in case the wires behind are not soldered/crimped properly.
Have fun.
Method 1
Method 2
Have fun.
already tried method 1
no luck
apparently the HU is so old that the spring clips dont bounce anymore
HU jus simply stagnates in position
my worst fears has just come true
looks like method 2 is inevitable liao
Thanks very much G8 bro !!!
