MWTB W213 E220D
melvinswk
  • 8 months later...
  • 1 year later...
On 1/25/2021 at 8:10 AM, melvinswk said:
Dear owners, I'm considering a pre-owned 17/18 E220d. Would like to check w existing owners if there is any know faults or recall for this model.
TIA!!!
Diesel is a good Alternative .
i used to owns a C253d & if u dunno dats a GLC250d Coupe 4matic. ,the mother of all SUV.
If u Nvr Driven or owns a Diesel ,u should gives it a go.
Read it up ……..
The Torque is juzz awesome,u Put in on D ,released the Brake ,the Car Runs by itself!
Servicing ,u must noe where to go.
Diesel car ,u cannot go to any Wshop.
First thing ,the Engine oil is of different Specs ,Look thru yr manual ,should be ACEA C3 or equivalent .
What’s dat?
Read it up.
if it’s a Euro5 & above ,Look for the Add Blue tank ,u gotta Fill it up.
No worri ,used veri very Long one but u must be aware.
As in 2022 October ,Diesel price at the pump have gone crazy same as petrol!
but u can go to those Cnergy or Smart pump in Amk or Toh tuck no problem ,I have done the research.
Another thing ,Diesel is veri very Dirty ,u gotta change yr Fuel pump every 2 years & if u needs to change yr Air filter ,u must buy Original ,cos the engine compartment is so hot it deform the whole filter housing if u use OEM types .
EO must change below 10k,as I says Plentiful of Soot ,their by product of Combustion.
A Dielsel saloon car will hit  1000km per tankful easily .
Remember ,dun buy a Diesel & treat it like a petrol ,u will have problems.
