Need help with driver's side door problem
Guest qes78
Guest qes78
Ok! I need help! This is what I DO know
1. Key into Driver's side door, key can't turn, doors won't lock or unlock, nothing moves
2. key into passenger side, key turns, all doors lock and unlock
3. From inside, when door close, all doors lock
4. Got no remote control locking
I took apart the interior panel, but nothing seems wrong. Any advice? happened to anyone before?
oh yes, I was very happy with the construction of the car when i took the panel out. All the parts were well thought out and fit very nicely, with all the parts keeping the panel to the door very well engineered! I must say I'm impressed.
If I remember correctly, a similar case happened a couple of years ago. Your barrel lock is screwed and you need to indent a new one with a new key. You have to sever the link btwn the barrel and the latch mechanism in order to replace it. Try the usual sources for ordering the parts - I trust they're able to help.
Guest qes78
I was afraid of something like that. No worries mates, I'll go down to my usual garage and update u guys again
