Fuel injector cleaner for w124
Guest mr w124
Guest mr w124
I just purchased a w124 and am having quite bad fuel consumption. is there any fuel injector cleaner that any of the members can recommend for this model? Thanks.
Viknesh
  • Replies 14
Guest sirBenz
1st of all welcome the club bro :)
Regarding ur Q.
I've heard from other forums the using fuel injector cleaner might harm the fuel divider. why don't u just change the injectors it cost abt $30/pc. alternatively u can try FC60 give Eddie a ring @ 92723423.
btw is ur ride 8v or 16v?
Sorri W124, hijack your thread ...
any idea what is a good engine oil viscocity to use for cars 10years and above ?
For starters, don't use fully synthetic oil. Previous experience with the fully synthetic oils is that they seem to "burn out" at a faster rate than the semi synthetic ones. Semi synthetic blends with no more than 30% synthetic oil is a good compromise. If you're using Shell/Mobil oils the viscosity rating tends to be between 5W-30 & 5W-40.
This list should help you decide on what type of oil to go for :-
Mercedes Benz Approved Engine Oil List
http://www.whnet.com/4x4/oil.html
Hiya Dial,
Thanks - so u suggest to go for mineral and change every 5000km then ?
Yo Raskie, thats my usual service interval. ;D Unless you whack your car real hard a 5,000km service interval is fine. General consensus is 10,000kms but in truth aggressively driven vehicles need a shorter interval.
Regarding ur Q.
Viknesh as Sir Benz has spoken - swap your injectors. :) Cleaners may or may not perform up to expectation.
Guest mr w124
hi Sir Benz. sorry for the late reply. been bogged down with work. i drive an 8 valve. just had it serviced and the consumption a bit better. but still hovering abt 400km for 58 litres. abt 7km per l. how many injectors would i have to change? and would it improve the fc or are my figures as good as it gets. Any info would be welcome. thanks.
Guest millionmilebenz
Hello Mr. 124! I think there's still room to improve in your vehicle's fuel efficiency. My W126 (3 litre engine) gets ~7.5 km/l, but it's a much heavier car. My dad's W124 (2.3 litre 8V engine) gets as high as 9 to 10 km/l, albeit with about two-thirds of distance done on highways.
Guest sirBenz
Hey mr w124,
I'm driving 8v as well, when i bought my car a year back, was getting 7.5km/l ( 80% highway).
This are things i done. to improve my FC.
1. New plug wires
2. New Distributer Cap & Rotor
3. New Nozzles ( btw u need 4)
4. KNN filter
5. New Fuel Pump
6. FC60 fuel additive( this stuff will clean out ur entire fuel system)
Now getting abt 9 -10km/l 80% on highway. Hope this helps.
Guest mr w124
Hi Sir Benz. Thanks. your info is greatly appreciated. can i just check did u change all of this at one go? n how much did it cost? was there an improvement in power? also wat petrol do u use? i was using 98 till a friend told me 92 is fine for this model. but with 92 my FC is worse.
Guest sirBenz
Hey mr w124,
changed the items 1 at a time..mind u that the results was not instant, took abt 4mths.
1. New plug wires $36
2. New Distributer Cap & Rotor $70 for both
3. New Nozzles ( btw u need 4) $120 for 4
4. KNN filter $100
5. New Fuel Pump $95
6. FC60 fuel additive( this stuff will clean out ur entire fuel system) $33/bottle i'm on my 4th bottle.
Power wise there is improvement, petrol wise i'm using combo of 95 & 98.
when you use 92, you have to re-tune your CO! than you will get your FC as good as before
i also alt use 95/98 or 97( go in Malaysia la)
Hey mr w124,
4. KNN filter $100
hey sir-benz
k&n filter got help meh?
Guest sirBenz
slightly perkier i guess
keltanky ]
Hey mr w124,
4. KNN filter $100
6. FC60 fuel additive( this stuff will clean out ur entire fuel system) $33/bottle i' wrote:
hey sir-benz
