w204 pfl
fesa704
hi guys/gals
hope to get some opinion from u guys?
got my 09 pre face lift,6 months back.
everything is a ok(naturally)
a month back,the suspension is like worn out,move a bit,more than usual.
so I get the shock absorber replace,all 4 of them.
decided to go for original mercs item,loves the way,when i first go it,
but after I got it replace,not from see&see but some w/shop not realli specialist in mb.
I ;ve a slight issue,here.
after I replace the absorber,there;s only a slight improvement,did I miss out something?
my w204 still dun behave like when I first got it !
any suggestion from u guys or point me to a shop where it can b sorted.
thanking u in advance.
  • Replies 3
thanks snsd555 for yr comments
when I bought pre own,i 'll splash on whatever to put it right.
I've actually  overservice the engine,flush the 5 speeder a couple of times,change all fluid,replace pad,replace torque arm,1 of them worn.
I was asking the w/shop guys should I change the absorber spring,dey laff @ me!
I dun bring to c&c cos its 7 yrs old&dey dun do good trouble shooting,juzz recommend to change dis change dat.
its my 1st mercs&its juzz beautiful.
anybody,care to chip in.
thanks for yr time
hi guys/gals
Did you check your engine mounting n gearbox mountings?
