ATF change for W211 E230
AHYEO
Hi All
Anyone who owns a E230 recently change the ATF ?
How many bottles ATF needed and beside that the parts that need to change like gasket etc..
Labour charges and any recommended workshop
thanks in advance
Ah Yeo
Bro AHYEO,
suggest:
Top Speed Motor - 20 Pandan Loop
Tel 6779 8562
They are specialist in all car auto transmission it seems,
I "sway sway" kana the dreaded 7G gearbox problem last week and it was swiftly repaired by them.
They seems to be expert in knowing how to repair it.
They offer other services on auto transmission too and I seen at least a dozen or more Merc Benz transmission units displayed on the shelf.
So you can check them out to see how much is ATF change.
My tranny repair is covered by my car dealer. :thumbsu:
  • 8 months later...
For Bro with W211 E200 1.8L engine...did you remember also changing the ATF-oil inside your Torque Convertor during your ATF servicing?
I only see my mechanic drain and take down the ATF rectangle pan to clean and change the filter.
I didn't see him unscrew any drain-plug at the Torque Converter area to drainout the ATF inside the torque converter.
Am I short-changed?
2006 W211 MERCEDES E200NGT
