W203 Lowered
Guest nismo502
Guest nismo502
Just sharing. This is my W203 lowered with Kleeman Springs. They are actually quite comfortable and not too harsh. Car corners flatter now and looks less like a bus :)
Before lowering
After Lowering
  • Replies 15
Guest nismo502
Very Nice!!! :)
What's the cost of the springs plus install charges? Where you got it done?
Thanks! :iconsalut:
I got the springs from a good brother here and had it installed in MBM. But if i am not wrong, you can get eibach springs for almost $600 installed from benzline. But dont quote me on it ;)
hmmmm.... i used to have the kleeman spring on my w203 and also finds the front not low enough.
yes, I think the front is not low enough either. I wonder why too.
Engine not havy enough....you might want to consider adding more load to the engine :devil:
Guest nismo502
Its either i put on more weight(in which i already have too much) or find a c36 halfcut ;)
Having said that, you heard of anyone who have done it locally?
Guest nismo502
I think a V's engine will add on more weight.....still not enough than add a V's super charger :devil:
Actually, I always wanted a V engined C class but I couldnt find one while shopping for my car. Maybe I should find a halfcut. Having said that, there is a SL55 body in the market now. My friend wanted to swap it into his SL350 but my mechanic wouldnt even touch the project with a pole :( He said he wouldnt dare to touch modern merc engine swap even though it is a halfcut. There are too much electronics and he is not ready to spend the next 3000 years sorting it out.
Thats why I asked if you have heard of anyone who has done that.
Guest nismo502
Sorry if i ask, 'halfcut' meaning the front half or rear half ?
If front, it should have come together with the dash which include most part beside gear box right ?
Halfcut meaning front. And it would include the gearbox. The last I found in KL was RM$28k. Imagine that, for less than $15k sgd, you get a c36 wannabe. niceeee
The problem is no one wants to start the project and they feared engine check light. Everything in a modern merc is connected to the ecu, down to the bloody taillight bulbs :P
Guest nismo502
Mercedes cars have a spring pad system. This pad is available in different thicknesses. Getting a thinner pad will make your car lower.
Thanks. That is most helpful information.
