Alignment off after shock absorber change
Gukkie
Hi, CNC just changed my front shock absorbers and now my alignment is off..When I center my steering wheel, the car pulls to the right and the steering wheel offset is slightly to the left..
CnC told me that shock absorber change does not require alignment..
Can anyone advise?
  • Replies 5
Yes, it SHOULD be done and NOT MUST be done therefore subjective question.
Gukkie when had the change - was it just the shocks or shocks and struts? The former does not require realignment but latter requires.
G13B Cultus | GC8C WRX STi RA | SR20DET S15 Hiper Silvia  | E82 135i M-Sports  |  W176 A250 AMG Sports
Can anyone advise?
It is best to check and realign the wheel after shock absorbers change. Check previous thread on car pulling left. There may be a need to change your fixed bolt to adjustable bolt (if you have not done so) to adjust alignment depending on the car you r driving
