09 W212 engine stall after ignition
teozy
Hi just bought a preowned W212. Every time after I off engine for 10 - 20 mins to run an errant or take a bite, the car's engine will stall upon ignition when I restart it. It will then start up nicely on second try with a long than usual crank. Happens when the engine is warm. Cold starts in morning are perfect. Anyone had experience with this problem and knows how to rectify?
Thanks
Teozy
  • Replies 3
it will only happen when engine is warm, when cold startup is fine. Can't be startup motor coz car managed to start but engine stall in 2 seconds. Cant be airflow coz car usually starts up ok on next try
